which set-up board.
which set-up board.
I am going to be racing at the club level soon and was wondering which set up board should i get for my xray t2 and why. what parts exactly should i get i know theres the ultimate kit and then theres the set up board and other things.
i dont want to pay the 300 for the ultimate but maybe in the 250 range.
i mean like station not just i plain board. what do you think i need to adjust my camber and toe and caster and all that and to remove tweaks from my chassis.
yeah just get a integy/eagle station and a digital caliper.
there is the $300 Hudy one. i seen it, looks great but i dont think you need it.
Tweak Station
I just bought the Hudy All in One Set-up Solution and have been happy with it. Every time I use it, it feels like my car is balanced and easier to drive. It makes everything more consistent like going down the straight away or even making turns to the right or left. If you don't want to spend the 3 bills, than buy the Hudy board and put a measurement sticker on one side, flip it over and use the clean side for more precise measurements. The Set-up system (camber gauge, or stands) is a must. If you're too lazy to use the 4 stands, just set up a pair of stands and do the front end first than the back. Buy those big screw-on nuts because it's a pain to screw on the wheel nuts to the camber gauges. Also the tweak station is nice. After I do my complete routine, I set the car on the tweak station for the final check. It never lies. If it's off, back to the work station.
what do you mean by a "tweak station" ?
there are great deals on ebay for setup systems got my brand new hudy (transparent) system with trinity board (transparent) for about $60 shipped. picked up an aluminum case for about $30 and i have the hudy ultimate setup system "clone" for less than $100
team magic has a new one out and it also looks good.
the new one from integy sells for about $120 and (board, 1 pair setup blocks, 1 pair setup wheels) it comes with a carrying case.
The tweak station help you adjust you car so there is even weight on the wheels.
If your looking for a custom pit board, make sure you check out B2 Designs - http://students.philau.edu/BAHNATKA2/bsquared/ . Stevie makes some very nice pit boards.
