Old 01-18-2003, 09:49 AM   #1
Default HELP!!! Need Setup Tips for Evolution III
NEEEEED some help setting up my evoution III for Tight Small Tracks (indoor and outdoor) In the Mod Class. I have a xxxs-gp for the stock class (See photo below). But I need some recommedations for my evoIII in the following areas:
1) sway bars
2) Motor - pinion - spur
3) planned on using futabas new s9550 low prfile servo - is this okay for mod????
4)where can I find TCS Rules???
capricess is offline   Reply With Quote
Old 01-18-2003, 10:08 AM   #2
1 & 2 -> Can't help... won't have my EVO III for another week or two.
3. Use 9550 on my 414m2 and love it (but not the price)
4. http://www.tamiyausa.com/events/tcs/
dalem is offline   Reply With Quote
Old 01-18-2003, 10:20 AM   #3
Trader Rating: 28 (100%+)
Default my setup
White tamiya spring/ 70 weight oil/3 hole piston
Shock all the way out on tower/yellow swaybar
Arms spaced two in front 1 in rear of arm.
Camber link Lower inner hole.
Sorex 28/Hpi red
Suspension blocks flat on chassis
Tamiya Blue/55 weight oil/3 hole piston
Shock 2nd whole in from the end of tower/Red sway
Arm spaced 2 in back /1 In front of arm
Raised suspension blocks{roll center} with 2mm spaces front and rear
Camber link in Lower inner location on the tower.
Sorex 24/Hpi reds.
I like this setup for carpet and for asphalt you may wanna lighten up the springs.Blue front/Yellow rear.
Hope this helps.I am running the 9550 and its the ****!
racenut123 is offline   Reply With Quote
Old 01-19-2003, 11:21 PM   #4
-CriMinaL- |RC's Avatar
Send a message via AIM to -CriMinaL- |RC Send a message via Yahoo to -CriMinaL- |RC
Thats a nice looking car you got their.... where did u get the red anodised parts?
-CriMinaL- |RC is offline   Reply With Quote
SETUP TIPS FOR TX/RX rcabj Malaysian R/C Racers 41 01-13-2008 12:55 AM
Setup tips for X-ray t1fk 05 Del32 Rookie Zone 1 09-29-2005 12:35 AM
B4 setup tips dado11g Electric Off-Road 28 07-26-2005 10:21 PM
setup tips? buddha Wisconsin & Illinois Racing 4 02-03-2005 12:47 AM
Setup tips for XXX-NT igkyoa Electric Off-Road 10 11-02-2003 01:21 PM
SEO by vBSEO 3.5.0
