Pros and cons about motor FAN
#47
One o the earlier posts stated fans on the end bell should push air into the motor. If the motor without a fan draws air from the armature towards the endbell, then this arragment would work against the effect of the aramature. With an open endbell, drawing air from the endbell should not only create a little additional negative pressure within the can, but also pull cooler air into the comm area where the brushes are located.
Years ago, there were absorbant sleeve the were placed around the cans and soaked with liquids. Water, would have a high capacity for absorbing heat, but due to the high boiling point and the heat required to evaporate the water, it usually did not work well. Alcohol evaporated much easier, evaporative cooling, but sometimes did not last the entire race.
#48
yeah im confused. should we be putting the fans so they blow air into the motor? or pull air out??
also... would a fan be totally useless if trying to cool a brushless motor? since its like sealed...
#49
A general note on thermoelectric coolers, AKA Peltier coolers/devices, are effective when used to PRE-COOL an electric motor...much different than on-board cooling. A lot of racers use both a Peltier for pre-cooling and then a fan (or two or even three) for on-board cooling.
I recommend the Crazy RC model...it features a much thicker copper base and copper clamp (which results in more effective cold transfer) than any other one commercially available.
http://www.crazyrcracing.com/1.html
sl4ppinb4ss3r- I have a fan bracket fabricated on my chassis to allow one fan to draw air into the endbell, and a second fan to draw air away from the endbell. (I personally think it is more effective to draw air AWAY from the endbell....)For a brushless application, it is useful to run cooling fans on the ESC, to prevent any thermal shutdown.
#50
Originally Posted by Jochim_18
.... but it only bring down the temp of the motor to a very minimal about couple of degrees lower and thats basically nothing.
#51
I did run my cooling fun last night and point it toward the endbell of my CP 19T, I felt the motor run strong finish first on 3 heats and TQ'd in the 19T expert class at my local club but unfortunately had a broken spool on the MAIN had to retire my car. I guesse cooling fan helped cool down the brushes a little bit
#52
Originally Posted by Guo Chean
nowaday you guy can used a small lipo cell to power your 1 or 4 fan in one short no matter how many fan you put it also wont suck so you battery power. you fan will be more high speed becasue lipo have higher voltage
#53
I use two watch batteries the my fan?? it works great to push air in. I get about 20 good races with the batteries. Just a simple neg to neg and pos to pos conection via a small mini plug. I un hook it in between heats and turn on my two fans below on my stand to keep things cool. I have also seen recently in ohter countries where they run a plastic tube that is made for transporting thin breakable long items? They use a heat gun and bend it to the end bell and attach it via zip or shoe goo. It looks pretty effective but I chose the easy way....
Team Academy / MRC / Team1rc.com / Tekin
B'
B'
#54
Originally Posted by fatbear
Can anybody tell me where to get screws long enough to go through the fan and then into the endbell? Are they 2.5mm or 2.6mm?
I used the Pro4 aluminum bumper standoff from Tobee.
(2) 3mm x 10mm grubscrew.
and 25mm fan.
you'll have to drill and tap the existing mounting holes for 3mm.
insert the grubscew with blue locktite then install and tighten with the
tobee standoffs.. after that install the fan.
very easy to do.
