New Novak Stock Brushless
#257
motor tech
Check it out.
http://www.teamnovak.com/tech_info/m...ech/index.html
They need to post the Inductance levels for the stock 13.5 motor though.
#260
I think inductance is something that cannot be measured on a standard DVOM. I believe it requires an inductance meter. Can anybody verify this?
The lack of positive identification will keep this motor out of our local track. Bummer. Hopefully that is something Novak will change soon.
#261
Never mind that last post. The link to the Novak site further up answered my question.
#262
Originally Posted by tomdav
Has anyone who tested the new motor want to give us some feedback?
Ran it outdoors in qualifying at my local club on Sunday - qualified for the A just a couple of tenths behind the person I normally am dicing with and that was on some old rubber tyres. Also had the disadvantage of being in the first heat meant one bump costing a couple of seconds and a few near misses that all add up.
Overall, I feel that Novak had done a good job and the tracks/drivers having nothing to fear. It was great not having to do any motor maintenance.
#264
Mike,
Is this motor available to buy in the UK yet?
#266
Originally Posted by brownpants
Mike,
It was quite good fun on Sunday even though I was in the last mod heat and first stock heat - certainly glad I didn't need to do anything other than charge the cells and goop the tyres
#267
Well, I tried Novak's inductance test and I can't make heads or tails out of the reading. As soon as you stop rotating the rotor, it falls to 0.00. There is nothing consistent about this test. The readings are all over the place. Can anyone else get some readings on any brushless motor and report back? I've tried the 13.5 and the Neo 3 star with poor results.
#268
If you turn the motor over tool quickly the meter will not settle in on a figure and the readout will bounce all over the place.
The figures I got were within the ranges on the Novak site and no where near as low as the minimum readings listed.
FYI, I have an inductance meter because I wind CD-ROM based BL motors for my r/c planes. It nice to have for testing new winds and when you have 10 motors that all look identical lying around
#270
Originally Posted by Mike Haswell
Not yet. They have only just started to escape in the States.
Do you know if this will be sold as part of a system? Or just the motor?
Darren
