Old 06-30-2006, 11:04 AM   #1
new92's Avatar
Default Paragon Traction action
oil based or no? Heard that Jack the Gripper will kill foams after awhile unless you clean it off. How hard is it to clean it off?
Also heard that traction action is better performing. How funky will it get the carpet if you use both traction action and others use Gripper?
new92 is offline   Reply With Quote
Old 06-30-2006, 12:07 PM   #2
Jack is quite easy on foam compare to paragon GE, I find paragon traction action has less grip when using on a mainly Jack the gripper track. Try the new Carpet Jack, it's better than anything I have try except paragon GE but no smell
caveman is offline   Reply With Quote
Paragon Traction Action psbarger Electric On-Road 40 05-31-2013 06:31 PM
Paragon Traction Compound Finsy Electric On-Road 9 12-24-2011 12:29 AM
Gearing for Traction/Slipper for Traction RCRat Electric Off-Road 2 08-27-2008 02:55 AM
Paragon traction compound ioxqq Electric On-Road 0 02-14-2008 11:51 PM
High-traction & low-traction? bloodlust Malaysian R/C Racers 4 12-06-2007 08:17 AM
SEO by vBSEO 3.5.0
