ANODIZING
ANODIZING
I wanted to know if the metalcast from dupli-color works on alumnun? If any one has tried this in the past please post some pics of the results. But heres a link if don't what this stuff is. http://www.duplicolor.com/products/metalcast.html
Paint
It's not anodizing, it's a translucent paint. Yes it will work on aluminum, no I have never tried it.
I've used it before... don't waste your time using it for R/C stuff. If you want parts to look anodized, then have them anodized.
Here's a shot of a PC case I did a few years ago using the duplicolor.. nothing spectacular, and the results don't look anything like anodized aluminum (that case was actually stripped and anodized a few years later.. night and day difference)
Actually, it's the meth heads that had lye taken off the market...not the tree huggers.
Caswell is really only good for dyes, desmut, and sealers (I haven't tried their stripper..drano crystals are a nice source of lye and they work fine so far).. their complete kits, however, are a ripoff. You can peice together just about everything in their kit from various sources for about half the cost.
I went nuts trying to strip off the origional anodizing on my 68 Chevelle's trim, I normally sprayed on EZ Off and it used to all come off when I was redoing aluminum. I tried everything, Oven cleaner draino... I ended up getting the lye from Caswell, it was a little pricey but from what I found out lye can be expensive. 15 minutes soak and the pieces were ready to be polished. Should have seen my contraption to soak the grill.
If you want to strip anodizing yourself, this is the only way to do it:
http://www.greased-lightning.com/pro...px?ProductId=1
It will typically strip anodizing off parts in less than 30 seconds... and will actually etch the aluminum if left on too long.
Also has many other household uses
As for anodizing itself, just find a local anodizer... they are all over!
As for the other guy asking about doing it at home, if you had of clicked on the Caswell link and read what I wrote your question was answered.
