Motor heatsink fan - push or pull?
I just purchased a 3 Racing motor heatsink with fan. The fan is set up to pull air away from the heatsink. I found this strange, since to my thinking, it would be best pushing air onto the heatsink to cool it. It is easy enough to turn the fan over if I want to push air onto the heatsink instead of pull air away...
Can anyone tell me if the fan should be blowing air onto the heatsink, or pulling air away from it? Thank you. |
Can anyone tell me if the fan should be blowing air onto the heatsink, or pulling air away from it? Thank you. alot of people undo the scews then screw it back on with the heatsink on and the fan blowing on the endbell,which is were the air is sucked in. change the fan unit on it,it isnt that powerfull. |
Thanks. Would I find more performance benefit with the fan blowing on the endbell, or sucking from the can?
From a computer standpoint, if you blow the fan into the heat sink the chip can run hotter as you are blowing the hot air in the case back into the chip. The heat sinks were designed to have the cooler air come in the sides and change to warm and suck it back out where the fan in the rear expells it. If the cars follow the same suit, it's better to have it blow out instead of in, but with the size of the fan and the heat sink, it may not make that much difference.
you wont necesarily get more performance but what you will get is a much more consistant performance from start to end,also brushes will be cooloer and last a bit longer. less heat=more effeciancy=more power for longer. a fan wont keep a motor cold under usage,it will stabalize the temp and performance though |
The fans we use aren't powerful enough to draw anything away from a heat sink. I have the same heat sink/fan unit and I replaced the fan with a Novak one and flipped it over and hung it out over the end bell. The heat sink can draw some heat away and act as a mount for the fan to blow air onto the end bell.
The 3racing heatsink/fan units are poorly designed.
I admit i got a bit excited and bought one out of curiosity. The fan is very weak and mounted too far away from the heatsink itself to do any useful work. Also, like many heatsinks there isn't much base aera to trasfer heat into the heatsink itself... Your best bet is to take the screws and spacers out and flip the fan... The fan just isn't strong enough to increase the airflow going over the heatsink when it's "sucking"... This puts the fan closer, and moves more air over the heatsink. If the heatsink covers the motor vents and you're certain the air is supposed to be expelled here then leave it... (I always though air came IN the can vents, and out the endbell vents on both sides - but that's just a blind guess really) A better solution is to mount a much more racing fan on there.. Much higher airflow. The biggest problem with a fan that "sucks" is that it needs to be cowled to really do anything. That is.. there needs to be an almost flush fitting ring around it otherwsie it just takes air that is near the fan are forms a convection current. |
The 3racing fan is pretty weak when run from the reciever, run it off the batt and it's much better.
I soldered the wires from the plug to the batt cons on the speedo and still have the plug to use as a switch. but do flip it over and hang it off the end over the endbell. |
Short Answer, Blow air onto the heat sink. It's easy to do, and easy to find if its working.
As mentioned before, a lot more considerations need to be made if u are sucking air from the heat sink. |
