Old 06-11-2006, 08:21 PM   #1
RaceBucks's Avatar
Default Much More Cell Master CTX 3 step charge feature
Opps, I posted this on the Much More CTX-D thread; don't see a CTX thread so I'll repost:
I have a question on the Much More Cell Master CTX 3 step charge feature. The manual talks about how to set it but not the best settings and tradeoffs.
1) What are the side effects of setting the Amp charge high (like 7 amps or more) in the 1st or second phase? I know that heat weakens batteries and that the higher amp setting will produce heat faster, but as long as the temp doesn't go above 110-115 degrees is it just a good way to charge faster?
2) How about punch? High current tends to give high punch, low current low punch, but what about this high current early and lower current later in the charge?
3) The manual example says 1/3 @ 7 amps, 1/3 @ 6 amps, last 1/3 @ 4 amps; has anyone played with other settings? Are there better ones?
one reply from CTX-D:
Originally Posted by trf_racer
Isn't this thread for CTX-D Discharger?
Anyways, Cell Master's step charge will not heat up the battery too much since 7 amps only go a certain amount of time follow by a low amp charge. Therefore, it should not harm your pack. The high current at the beginning is to stablilize the battery pack and to give more punch. Lastly, 1/3 should be 7A, follow by 0.2A for the battery to rest, and lastly, 4 amps.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 06-11-2006, 11:41 PM   #2
goto nexus racing website, they suggest something like
7.0 amps; 3000mah
0.2 amps; 20mah
5.0 amps; end
i used it, never found any noticable benifits
XingXing is offline   Reply With Quote
Old 06-12-2006, 12:15 AM   #3
XrayFK's Avatar
What kind of batteries are you running? If you are using IBs, just stick with a linear charge.
XrayFK is offline   Reply With Quote
Muchmore Platinum Cell master Lipo charge question 66Racer Radio and Electronics 1 06-16-2009 10:08 PM
APS Dyno Charger S3 Step-charge controlledchaos R/C Items: For Sale/Trade 2 12-16-2006 03:46 PM
APS Dyno Charger S3 Step-charge.... $120.00 killerjvf R/C Items: For Sale/Trade 3 12-14-2006 10:07 AM
APS Dyno Charger (S3 version) Step-charge killerjvf Electric On-Road 2 09-10-2005 09:26 AM
Linear Or Step Charge DIMO Electric On-Road 14 06-26-2005 11:24 AM
SEO by vBSEO 3.5.0
