Gearing Xray Evo2
Gearing Xray Evo2
What pinion will i need to run for the best performance on a tuned 19t motor. I am running a 120spur(64p) and my internals is 2.11 and the tires i am running are cs27 the track is a good size track with only a couple corners that are tight but rest are small sweepers with a few short straights and one long one..... any suggestions
I was runnning a 19t in my evo2 and i used a (48p) 96 spur with 22 pinion and it was perfect,your track sounds exactly the same as ours
heres what our track is that we are running on look at post 10 on this page
http://rctech.net/forum/showthread.php?t=112022&page=1
what was your final drive ratio on the setup? cause i can match it using my 64p gears
Suspended
yopu need between a 27 and a 28 to amtch his ratio. but i wouldnt go by that unless he is running the same 19t motor as you. what motor do you have.
