Old 06-08-2006, 11:03 AM   #1
TEM's Avatar
Default Wheel cut outs in body?
What diameter do you make your wheel out outs in a TC body? Also, I've seen some folks leave the top 1/3 of the rear wheel cut outs intact (looks likes and old caddy). How does that help?
TEM is offline   Reply With Quote
Old 06-08-2006, 02:30 PM   #2
Fastburn's Avatar
Trader Rating: 16 (100%+)
leaving the rear part gives a little more strength for running mod motors.
as far as wheel cut outs, I like to mark where the centre of my axle is, then from there use my OLFA hole cutter and cut out a few mil from the outside of the tire. From there, I poke at the body to see if it gets hung up on the tires and trim from there. I dont leave extra body in the rear tire location as my body does not require it for 19t.
Nate Talaskavich
Fastburn is offline   Reply With Quote
Old 06-08-2006, 03:56 PM   #3
Skiddins's Avatar
Much as Fastburn said.
For my rear wheel arches I measured where the axle was when the wheelbase was set short, and when it was set long, then basically score the two arches and where they meet in the middle at the top (there will be a slight V shape left due to the two separate circles not being lined up). Just trim this out with a knife.
Make sure when the body is pushed inwards past the tyre that it will not catch on it as this will cost a lot of time if a marshall has to sort it.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RD Disco
Skiddins is offline   Reply With Quote
Old 06-08-2006, 05:34 PM   #4
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
pick up a circle cutter makes it alot easier too, just score the bodie and you can rip out a perfect wheel well
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 06-09-2006, 01:53 PM   #5
TEM's Avatar
Thanks guys... I already got a circle cutter.. I was curious what dia to set it at. But I like the tip on cutting 2 arches for different wheelbases for the same car.
Losi XXX-CR wheel, tire, body, arms lot K.Copeland R/C Items: For Sale/Trade 4 01-29-2008 02:27 PM
wtb: Rc18t stuff tires, body, wheel adapters, cvds, etc.. tedd69 R/C Items: Wanted to Buy 2 10-05-2007 01:04 PM
Bodz MF2 Body and 1/10 Drake Tire Wheel lot motoazure R/C Items: For Sale/Trade 5 11-07-2005 02:01 PM
Tamiya F201 4 wheel drive and Brand new body BDR609 R/C Items: For Sale/Trade 4 06-04-2004 10:40 PM
mounting body on car so wheel do not scrape imjonah Painting, Designs, Graphics and Photography 3 05-19-2004 01:44 PM
SEO by vBSEO 3.5.0
