Old 06-03-2006, 06:10 PM   #1
Default Building a discharger?
ok ive decided i want to build a 30amp individual cells discharger very simmilar to the integy 0-30,
i worked out that i need .1 ohm round wire resistors but i cannot find them in australia so if any one knows were i can buy them please let me know also
wht should i use to connect to the batteries can u buy tabs like those on the novak smart tray or it a screw in pin idea like on the integy 6s a better design? thanks in advance
Josh P
to make Keith happy
Corally phi
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 06-03-2006, 11:46 PM   #2
I spent hours looking for tab type connectors and didn't find anything ideal, so I wouldn't waste your time with that. You can buy the integy screw ones, but for $1.50 I think, which seemed a bit expensive for me on top of all the other costs. If you find anything else let me know.
ralph_c is offline   Reply With Quote
Old 06-04-2006, 12:03 AM   #3
Drewdc90's Avatar
You could try tool clips that can be bought from a hardware store. Cut them in half and screw them into timber or something non conductive. I found they work really well and are cheap. They come in differant sizes.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 06-04-2006, 12:18 AM   #4
pjf's Avatar
try wes components for the wire wound resisters they have 0.1 ohm 10watt wire wound ceramics $1.30 each
pjf is offline   Reply With Quote
Old 06-04-2006, 07:34 AM   #5
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
HERE IS MY TRADER FEEDBACK ON HOBBYTALK. http://www.hobbytalk.com/bbs1/itrader.php?u=8257
burbs is offline   Reply With Quote
Old 06-04-2006, 09:23 PM   #6
Originally Posted by burbs
Add one small diode below R1 for Sure Cut-Off, no more rattling / buzzing sound from relay coil when battery voltage approaching desired cut-off voltage..
Faiz is offline   Reply With Quote
what's the diff btwn 0-30 discharger & novak smart discharger straightaway Electric On-Road 9 09-12-2006 06:15 PM
Wanted: Discharger and/or Discharger building info oMONSTERo R/C Items: Wanted to Buy 7 06-20-2006 05:24 AM
need help with building a discharger maximebeauvais Electric On-Road 0 12-08-2005 11:43 AM
need help building a discharger nuttcase21 Electric On-Road 3 01-01-2005 09:16 PM
Wanted Integy Octane 2 Discharger or Trinity Realtime 2 Discharger FUK_WRX R/C Items: Wanted to Buy 0 08-02-2003 04:23 AM
SEO by vBSEO 3.5.0
