Old 05-26-2006, 04:16 PM   #1
Default reedy quasar pro vs ce pitbull charger
What one is better? and i know ill need a powersupply for the pitbull. but charger to charger are they about the same? Thanks
RCkid16 is offline   Reply With Quote
Old 05-26-2006, 05:42 PM   #2
drew85's Avatar
charger is a chager, unless it has somthing like step or something else. I heard they had problems with the reedy one, I never did but i read it somewhere.
drew85 is offline   Reply With Quote
Old 05-26-2006, 06:34 PM   #3
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
no they aren't the same.. my first digital charger is reedy quasar pro..
and it sucks.. not really.. but if the version is not upgraded its not worthy.. coz i mistakenly plugged it on 220v and blows the diodes.. 8 diodes were burned.. mine was brought to a friend for repair.he searches for power supplies that are 110v to look for those diodes for quasar pro,and it worked again, and we changed the fuses. it means that if u got the 1st version its bad, bcoz all release of the quasar 1st version are defective fuses.. if you send it to quasar they will fix the version of the firmware for you..
what i like about this charger it has discharge function up to 20amps.
1st version:
all qusasar w/1st version (defective fuses)
tends to false peak
2nd version:
upgraded firmware
all are ok
CE pitbull x3
this is my 2nd digital charger.. and i'm very happy with it.
it charges the battery at its full potential.. no need to say its light in weight and very small. it can fit into your toolbox..
green backlit
longlockout feature (eliminating false peak)
up 7amps of charging with .1 increments
no discharge
so in all.. you cant go wrong with pitbull X3... till now im using this charger. its much good in charging.. thats all.. hope these helps..
nikkiesteban is offline   Reply With Quote
Old 05-26-2006, 08:29 PM   #4
Joel Lagace's Avatar
Default quasar
First off not all Quasars where defective, Reedy recalled them all to be on the safe side.
I own 2 of them and both where first versions that ran flawlessly for 2 years before i bothered to send them in for the recall upgrade. Before and after the upgrade i had zero issues charging anything with these chargers. FYI if the charger is 120v and you plug it into 220v then its not the chargers fault for blowing u diodes. Why not try pluggin your pitbull into 120v and let us know how it works out
-1-8 cell charging(version 2)
-new version has short lock out based on MAH chosen during setup
-adjustable trickle charge
-adjustable charge current
-adjustable delta peak
-20amp discharge(for this reason i will never part with the charger)
-beeps that you can actually here. (LOL my club hates my charger)
-will charge dead shorted packs
There is no reason to go to the pitbull if you can get them at similar prices. Charger vs Charger they are equal.But its the extras that the reedy does that makes it the better charger.
"Without Rules its just Backyard Bashing!"
Joel Lagace is offline   Reply With Quote
Associated Reedy Quasar Pro Charger DustinR R/C Items: For Sale/Trade 5 03-24-2008 05:52 AM
Reedy Quasar Pro Charger Callmedan Electric Off-Road 1 01-21-2007 07:35 PM
WTB---->Reedy Quasar Pro Charger ThePrfctGetaway R/C Items: Wanted to Buy 2 08-04-2005 08:27 AM
Reedy Quasar Pro Charger Joe B R/C Items: For Sale/Trade 23 06-29-2004 12:32 PM
Reedy Quasar Pro - charger Nexus R/C Items: For Sale/Trade 15 12-21-2003 04:04 PM
SEO by vBSEO 3.5.0
