Hudy 4.5mm nut driver
can anyone confirm that this will fit on motor spring posts?
Wondering if it is deep enough for the post and also if the cut on the driver goes low enough, hard to explain: if you've seen the trinity 4.5mm spring post driver you know it doesn't go down far enough to grip the nut part, unless you grind the tip I guess..
I searched
thanks
I searched
thanks
Not sure about the Hudy or Trinity wrench but the Integy 4.5mm hex wrench works great for me.
http://integy.automated-shops.com/cg...23106100585.cb
prob will go with the integy but I wanted my tools to match and everyone seems to be out of the integy..
Integy is the only one I have found that works. Easy to find in all my Hudy tools.
