Motor Lathe
after reading on some website, it seems that brushed motor maintenance is really a headache task. i have come across many ppl using motor lathe, such as Integy X-MOD super Lathe or Hudy lathe, to cut the motor's comm. i mean is it neccessary to invest in this machine?
step to maintain motor performance : - cut comm using motor lathe - polish the copper bushing - sand the motor shaft - realignment of the brush slot - timing the motor to certain degrees have never thought of all these issue when i started RC, coz it just means dumping more and more $ into this hobby, basically spent around USD1000+ just as a beginner. so i was thinking if its better to use brushless motor (pay once and do not need to undergo all that tedious task. as for the motor lathe, can anyone recommend some cheaper ones, cos they are just to cut the comm. |
Cutting the comm is one of the most important things to do for a motor. While it is not necessary to spend hundreds of dollars on a top of the line lathe, if you want to maintain your motors then you will need a lathe. Just make sure you set it up correctly (correct bit height) and any decent lathe will do the job.
If you're just into drifting or only race occasionally, you dont have to buy a lathe. See if any of the hobby shops in your area are able to cut the comm for you - usually they may only charge a few dollars for the service.
If they dont, you could send the motor off to a Tuner and get them to freshen the motor up, usually there will be a charge for this also. If you have a group of mates who are into it and none of you have a lathe, you could buy a lathe and charge them all a few dollars to cut thier comms when they need doing and make the cost of the lathe back :) Or buy a brushless system :p |
may i ask if brushless system is really no maintainance? if that the case i might consider coz brushed motor is really a headache. but i just bought novak GTS. :rolleyes:
All you need to do is dismantle the motor every so often to clean it out and perhaps to re-oil the bearings. No regular maintenance like a brushed motor with comm cutting and replacing brushes.
Problem is the price of a brushless system is around the same as good comm lathe... |
guess i better start saving for Novak Brushless system, btw, which series of novak brushless is best for drifting? i remember seeing 4.5R or 5.5R, which cost around USD440+
You can get the Cobra Lathe for around 160 new, around 100 used and then they have a power base for it that lets it run from a battery pack rather than needing a ps/charger. That would be alot cheaper than the brushless, but then over time the brushless would probably save you some money.
hey.. having a brushed motor and doing all those " headache" stuff u said is the essence of it...its where the fun and it is where to determine your skills and love for your car... its where pride is all about...making your stock motor faster than the others is kinda hard but its how it should be....
you can also get the integy auto lathe is just for 145$ at towerhobbies...plus 20$ off i think..or 10$ i think......i bout mine one lathe one co27 plus a comm drop for $170+
I want to race. Racing around here is with brushed motors, so properly maintaining a brush motor is simply a necessity. I bought a good used lathe for around $100.00 and I'm glad I have it. Other than that, I'd imagine you need to tear down a brushless motor to clean bearings and remove carpet fibres from the shaft just like a brush motor. If brushless was an option, sure I'd go for it, but at this time it isn't.
ok thanks, i think i shd look for 2nd lathe coz doesnt need brand new
