Old 05-18-2006, 06:51 PM   #46
Chris Adams's Avatar
Can someone put a diagram of the arm angles and corresponding rc term
TEXASEOS.net, SpeedzoneUSA, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2016
Chris Adams is offline   Reply With Quote
Old 05-18-2006, 07:51 PM   #47
Rick Worth's Avatar
Pro squat is when the rear of the arms are mounted higher than the front. Anti squat is when the front of the arms are mounted higher than the rear.
Rick Worth is offline   Reply With Quote
Old 05-18-2006, 08:00 PM   #48
CarbonWorks's Avatar
In my powerlifting days I competed in the Pro-Squat division. The guys I beat were using too much Anti-Squat.
CarbonWorks is offline   Reply With Quote
Old 05-29-2006, 09:59 PM   #49
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Carbon works- Ralph didn't exactly "tell" a guy that posts on here how squat works... Rocko works for Ralph at RCAmerica. Rocko doesn't post much, but his posts are always informative. Ralph almost never posts cause he's so busy but many times will ask Rocko to post information for him.
Rody- you guys are 100% screwing up racers trying to learn chassis dynamics.
The biggest misconception in squat and dive is simply this: Normally weight transfer causes the car to lean towards where the weight is being transferred because of roll moment and the CG being higher than the instant centers. However, in the case of squat, it's not about the leverage of CG over roll centers, it's about torque and the opposing forces created by rotational mass.
With a solid axle suspension (like a 1970 Chevelle for example) the pinion gear tries to climb the ring gear and effectively forces the axle to push away or separate from the chassis. That force drives the tires into the pavement and in some cases where the instant center has been modified, will actually apply more than the car's total weight to the tires momentarily.
With our independant suspension cars, that pinion/ring gear action is absorbed back into the chassis, but a Carbonworks stated, the angle of the hingepin still causes a reaction of the rotational weight (tires, wheels, axles) against the unsprung weight of the chassis.
Sometimes I have a hard time understanding new concepts such as this and find that using extreme examples help me to understand, so here's one that will help... Think of the rear hingepin being at a harsh angle like 45*. You're looking at the car from the driver's side and that angle is like this- /
-so the car might be represented like this: <O___/O (with the slash being the rear hingepin angle) It's easy to see that when the rear tire tries to roll forward, it will also try to move up as well. This takes weight away or off the rear tires even though the rear of the car will drop immediately. Hence the name prosquat.
- the direct opposite of this is true as well: <O___\O Now it should be very simple for you to see that when the rear tire tries to accelerate, it will move downward and try to push the chassis up. This applies more weight to the tire and also reduces the amount the rear chassis squats down; antisquat.
Hope my simplification helped someone. If it did, please buy an Xray...lol.
BigDogRacing is offline   Reply With Quote
Last person to post doesn't get JACK SQUAT! Phatkat Chat Lounge 66 06-21-2009 11:46 AM
Anti-squat question jon123 Electric Off-Road 18 09-21-2007 10:39 AM
B4 Anti Squat Shims BuggyKing Electric Off-Road 3 06-25-2007 07:47 PM
Effects of anti-squat? mx048 Electric Off-Road 5 06-29-2005 06:33 PM
2 deg. anti-squat Billy Rookie Zone 1 12-09-2004 01:45 AM
SEO by vBSEO 3.5.0
