JR XR3 Queries
JR XR3 Queries
gidday,i have a JR XR3 radio,anf a gmV12 speeeedo. my problem is full braking action occurs at the start of the trigger movement,and as more brake is applied, the effect is less and less, ie.to explain it better, it seems to me that the trigger movement, on the braking side only is reversed..
anyone know how to fix this prob?
thanks
Rob Storey
Topkart Comer Australia
thanks
Rob Storey
Hmm, I have an XR3 and don't see that effect. Maybe check the esc setup. I'm not familiar with the gm esc's. Did you try and dial out some brakes with the switches behind the trigger ...can't remember if it's the A or B switch. I'd make sure of the esc setup and turn down the brake rate and see if thats helps.
