Corally SP12X
#421
#422
The "normal" tyre of all of us UK corally guys is Parma Magenta front with Grey rear. I think the bite in our carpet tracks is generally a fair bit lower than in the US, and we alwasy run on odourless adative.
#423
So on Carpet without a groove like at a big race do you think Jaco dbl pinks would be a good choice?
#424
Im using the Jaco Prism double Pink rear/Lilac front when the carpet have less grip or on low bite carpet.
And when carpet gettin more grip or on mid bite carpet im using Yellow rear/Lilac or Purple front.
Thatīs for the 19T Classes.
#425
I ended up taking all the electronics out and never even running the car. I decided to run a different car for the simple reason that I'm already running another 4 cell class and didn't want to have two different battery pack configurations. Silly reason, I know...
If anyone is interested in a never run US Spec SP12X with some NIP parts and gears give me a shout I'll give you a nice deal.
#426
Spring collars?
Hi,
Does anyone know if there IS any part number for original corally front end spring collars?
There is no part number shown in manuals.
#427
http://www.superiorhobbies.com/istar...d=COR75570!SRC
Jeff
#428
while the topic of low traction is being discussed, what are people using on crc carpet with NO traction compound allowed?
#429
You could use SXT 2.0. Although it is not considered a tire traction compound, it is an oderless tire conditioner.
#431
Thanks for the tips, but this track doesn't allow any tire sauce I was looking for tire compounds. I ran purple pink last time. it was ok, till the residual compound from another track wore off.
#432
Are you using the 1.6mm T-bar?
.018" front springs? or .016" ?
Thin dampener lube, like significantly thinner than Corally red?
#433
it seemed close in terms of front to rear traction pushed more that spun, there just wasn't much overall traction. thin tbar, .018 springs, lube was soft, crc white cap i think, not positive. Ill have to try the different front tires. I gather that as soft as possible is the way to go for springs and damping?
thanks
btw does anyone know what corally red is equivalent to in diff fluid?
thanks
#434
#435
anyone knows what shore or colour are the tires that comes with the euro specs?
