Old 05-13-2006, 04:30 AM   #1
Default Shock angles
Hey i was woundering wut does it do when u alter the angle of you shocks ?
abcd123 is offline   Reply With Quote
Old 05-13-2006, 06:14 AM   #2
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
It will adjust / alter the dampening of the shocks. In the front, moving to the outside will reduce steering while increasing dampening. Moving inside will add steering, but decrease dampening. In the rear out side will decrease traction and increase dampening, inside increases traction and decrease dampening.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 05-13-2006, 06:30 AM   #3
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by abcd123
Hey i was wondering what does it do when u alter the angle of you shocks ?
Leaning the shocks in will also decrease the crispness of the cars response, the car will feel lazy to steering input.
Slotmachine is offline   Reply With Quote
Old 05-13-2006, 03:59 PM   #4
Hey what type of setting do you think i should use on smooth white concrete with a layer of dust on top.
And for really rugged ashphalt.
O im am running a Tamiya TB-02 with kyosho 30s with hard racing inners
With a johson 540 motor.
Old 05-13-2006, 04:40 PM   #5
protc3's Avatar
changing shock angle changes the leverage the arm has to compress the spring.laying them down has a softer feel through the corner because it has more leverage to compress the shock causing the shock to absorb most of the weight transfer to the wheel.standing them more verticle will give you more side bite because it is harder to compress the spring and transfers more weight to the wheel rather than being absorbed by the shock.a car that has the shocks stood up too much can have a very twitchy feel.you need to find the angle that is good for your track.start with them stood up and then start angling them in until it feels best.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Camber angles ("roll center") question? TommyGun43 Electric On-Road 5 08-15-2008 07:59 PM
FS: LST shock with hard coated body and Ti-Ni shock shaft yahhoo R/C Items: For Sale/Trade 6 03-27-2008 12:04 PM
TC3 FT aluminum shock tops w/Lunsford "quick tune" shock mounts? billwilner Electric On-Road 2 01-06-2005 07:49 PM
cutting camber angles on foam tires Marcos.J Nitro On-Road 3 12-01-2003 12:25 PM
NTC3 Shock and Team Associated Shock Caps Question jcrouse Nitro On-Road 4 07-13-2003 09:11 PM
SEO by vBSEO 3.5.0
