Old 05-10-2006, 09:59 AM   #1
Default TC4 not getting any power to the wheels. .
I just picked up a TC4 yesterday, I am completely new to RC cars. My room mate, who has the TC3, assembled it yesterday, and barely any power reaches the wheels. The only way the wheels will spin is if the car is lifted up off the ground. The gears match perfectly from the motor and the drive shaft spins flawlessly.
Any suggestions?
TheKamaSupra is offline   Reply With Quote
Old 05-10-2006, 10:05 AM   #2
koabich's Avatar
Send a message via Yahoo to koabich
Any one of the following or any combination of:
1) The pinion gear is not tight on the motor shaft
2) The mesh is not set correctly between the pinion and spur gear
3) gear mesh inside the diff housing is not tight enough
4) Your motor or battery is dead
5) Your ESC or radio is not set correctly.
koabich is offline   Reply With Quote
Old 05-10-2006, 11:18 AM   #3
Brent Owen's Avatar
Yup, check those and also check the tightness of the diffs, you might have them so loose no power can be put down under load. Associated if I remember recommends turning the diff screw (in the outdrive) in till it bottoms out and then back 1/2 turn out as a baseline.
Brent Owen is offline   Reply With Quote
Old 05-10-2006, 04:29 PM   #4
Follow instructions on the manual. You might have a loose differential, check it out! Oh, by the way, did you put ball diff grease on it?
macgyver1432000 is offline   Reply With Quote
Old 05-10-2006, 04:33 PM   #5
Send a message via AIM to R/C Anonymous
My guess is a loose diff or two.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 05-10-2006, 05:07 PM   #6
ford_racing's Avatar
Send a message via MSN to ford_racing
I say you are right
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 05-10-2006, 05:28 PM   #7
wouldn't it also act this way if the axle pins were missing? i left a car at a friends house and was wondering why it was driving funny the next weekend. someone "borrowed" one of my front ones. sabotage!!
bdrift is offline   Reply With Quote
WTB LARGE MT WHEELS TIRES & WHEELS 17MM + STIFF REVO SPRINGS jsm11 R/C Items: Wanted to Buy 5 07-18-2008 08:11 PM
5 sets of wheels/tires. slick, treaded, and drift. 4 dish wheels bionictony R/C Items: For Sale/Trade 2 07-12-2008 08:02 AM
ELECTRIC POWER WHEELS pink_sleeve Oval, Larger Scales and More 3 05-28-2007 07:19 PM
M Chassis aluminum wheels - Power Supply w/pics needrcspeed R/C Items: For Sale/Trade 5 04-28-2007 09:42 PM
Losi buggy/truck wheels, tourer bodies, bling wheels I'm_Serious Australia For Sale/Trade 0 02-05-2006 05:15 PM
SEO by vBSEO 3.5.0
