Old 11-16-2009, 08:17 AM   #1051
SteveM's Avatar
Trader Rating: 125 (100%+)
The 3Racing purple alloy parts for the Cyclone S are a drop-in fit and work very well. I have the bulkheads, bulkhead covers, motor mount, mid chassis heatsink, servo mounts and steering belcranks on order. I'm updating my plastic S version to run in my club's 13.5 BL sedan class.
SteveM is offline   Reply With Quote
Old 12-15-2009, 03:35 PM   #1052
Default need setup help
I got a Cyclone S as a early christmas present. I 'm going to run vintage, stock motor, 6 cell 4600s, other than 5mm ride hieght I'm lost. I should tell ya the track is ozite 30' x 60'.
broqenjeep is offline   Reply With Quote
Old 01-09-2010, 04:13 PM   #1053
cherry2blost's Avatar
Originally Posted by bboard View Post
Anybody use the 3Racing alum.? I was looking and it cost about half the price to upgrade certain parts to aluminum with 3Raing than it does with the HB aluminum.
I'm about to get this kit in a few weeks, any tips, tricks, or suggested upgrades out the box? I'm gonna be running 13.5 and 17.5 lipo, probley Novak Havok. I saw a few pages back abou tslotting the motor mount for brushless, will I need to do that or can I just run smaller spur/bigger pinion or swap for 18t pulley?
If you order from Toy east in Hong Kong the 3 Racing parts are even cheaper, here is a pic of my Cyclone-S with a 'couple of 3Racing upgrades..... OK so it's ALL of them lol. but you can see what a full 3R cyclone looks like at least.....
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 01-19-2010, 07:41 PM   #1054
mlight13's Avatar
Trader Rating: 40 (100%+)
Hey all, I just finished building my Cyclone S and I am having a problem. My steering tie rods are hitting against the support piece in the center of the chassis that the hinge pins connect to (Part number 61236-2 that the front belt goes through). The only way for them to clear the piece is to lower the ride height to 3-4mm or so. This is way too low. I double checked my pieces and steps and everything was put together right according to the instructions. Has anyone else had this problem? It will turn full left and right with some force but it doesn't seem like it should be that way. I have built many cars before so I kind of know what I am doing. Any ideas?
Mark
mlight13 is offline   Reply With Quote
Old 01-19-2010, 08:17 PM   #1055
MD
MD's Avatar
Trader Rating: 105 (100%+)
I haven't had that problem. You may want to check the center steering column
with the spring tension. Make sure it's assembled properly and the spring is tight enough.
MD is offline   Reply With Quote
Old 01-19-2010, 08:21 PM   #1056
warnos's Avatar
Mine did the same thing.. it only just touches it a little bit.. my TC does the same thing I just got the dremel out and took a little bit off the part it is rubbing on.. it only seems to rub on it at full lock..
Cheers
warnos is offline   Reply With Quote
Old 01-19-2010, 09:35 PM   #1057
mlight13's Avatar
Cheers
Thanks...I will try the dremel thing and hope for the best.
Mark
Old 01-20-2010, 02:45 AM   #1058
Cheers
+1
same problem here and same solution and also make certain that the ball ends are screwed in all the way to the steering block
Old 01-20-2010, 08:50 AM   #1059
I've got a problem with my Cyclone S where the center pulleys seem to wear out easily.
I'm running an EZ-RUN 5.5t setup and I mostly just parking lot race/bash. I know that 3Racing makes a Delrin set of pulleys and that HB makes an aluminum set. Do these hold up better than the stock plastic pulleys?
Also, are there any wider belts available for this car? My friend has two older RS4s and the belts on his car are about twice as wide as the Cyclone. They definitely hold up to power and abuse better than the skinny Cyclone belts which I have snapped.
Thanks.
Aceldama is offline   Reply With Quote
Old 01-22-2010, 08:52 AM   #1060
ozvena's Avatar
Is there any issue with the stock front bumper? Do you replace it with something that works even better? Thanks!
ozvena is offline   Reply With Quote
Old 01-22-2010, 09:27 AM   #1061
MD
MD's Avatar
On mine I bought a BRP bumper made for a TC3 and modified. I stopped breaking steering knuckles.
Old 01-22-2010, 09:48 AM   #1062
ozvena's Avatar
Is this what you use?
http://www.myatomic.com/catalog/viewsku?sku=BRP6225
Do you use it with all stock parts or there is something else I need in addition to the bumper?
That looks like a plastic, so do you put the stock foam bumper on top of it?
Old 01-22-2010, 09:58 AM   #1063
mlight13's Avatar
Can someone recommend me a starting gear ratio for my Cyclone S? I just built it and I will be running an 27T brushed motor (Trinity CO27 or Reedy Stockstar) at first before I drop money on a brushless system. I have heard some people running as low as 3.5FDR and others running as high as 5.5FDR. I will be running on a medium size asphalt track. I am also switching to 48pitch gearing so some gear sizes will be helpful. My local crowd pretty much all runs brushless so there is not much local help with it. Thanks in advance...
Mark
Old 01-22-2010, 09:59 AM   #1064
MD
MD's Avatar
Yes, that's it and I put the foam on top. It's not exactly plastic. It's some a material I've heard people call Kidex, I think.
Old 01-28-2010, 09:23 AM   #1065
ozvena's Avatar
When assembled togather, is the foam stikking over the plastic bumper? By how much?
I just wonder what happens when you hit a wall, which part absorbs the impact first.
Thanks!
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
