Old 07-13-2009, 08:48 PM   #931
Hey guys I'm new here. I just got my cyclone S setup and I reversed it into a curb medium speed and I broke the battery clip post.... I supper glued it but wondered if other people have had the problem. Also I was wondering whether replacing the belt pulleys and putting aluminum ones is worth it?
GWTW is offline   Reply With Quote
Old 07-13-2009, 09:08 PM   #932
GasGod's Avatar
nope to both;Get a 3racing graphite chassis first@ around 35bucks--you will be happier.I did
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 07-13-2009, 09:21 PM   #933
vazzo's Avatar
Trader Rating: 100 (100%+)
In the two and a half years Ive run the cyclone S I have only broken a left front knuckle I've only raced it though never bashed. I wouldnt buy anything 3 racing for the car to be honest you might as well go buy a second hand cyclone black instead of upgrading the chassis of the S and I would keep the rigid tub chassis as it doesnt tweak like a carbon fibre chassis. Upgrade the centre layshaft system to the exact same one in the cyclone TC so you have more gearing options as well. It's a great car in the right hands But just stay away from anything 3 racing as it throws out other things on the car ie I used 3racing bearing holders and they were 1 squashing the bearings and 2 they didnt allow the belt to be adjusted freely enough so I went back to original plastic ones.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-06-2009, 08:31 AM   #934
Does anybody has the link to the manual of Cyclone S Drift Special Edition?
If not, does it come with universal shafts front/rear?
Thanks.
Herman Chauw
http://www.hermanchauw.com
hermanchauw is offline   Reply With Quote
Old 08-06-2009, 09:00 AM   #935
bvalistic's Avatar
Trader Rating: 31 (100%+)
Default spacer
Originally Posted by airwoods View Post
For those of you running the s have you tried running the larger 2mm spacer in front of the rear axel to make for a longer wheelbase?Right now i have the smaller 5mm one in the front and was wondering if i swapped them it would give me more rear end grip and not loop out as much when harder on the throttle around corners.
rear end:
put the 2 mm shim at the back and .5mm front (short wheel base) and make sure you do the same at your knuckles...yeh more rear bite...as for me i just let the front end stock(long wheel base)...hope this helps...just try it if it does'nt work for you just put it back the same way and do some other changes...
bvalistic is offline   Reply With Quote
Old 08-06-2009, 10:11 AM   #936
Hello, Im just wondering were does everyone get there 3racing parts I'm looking for the main chassis and upper deck specifically.
Old 08-06-2009, 06:37 PM   #937
mr fit's Avatar
From www.3racing.com
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 08-06-2009, 06:43 PM   #938
mr fit's Avatar
I would also get the aluminum c-hubs the front knuckles and the rear uprights . 3racing products are quite good I've never had a problem. Good luck:
Old 08-13-2009, 07:08 AM   #939
Sohlman113's Avatar
I have just put together a cyclone s and I just put on the tc schocks on. However I am still looking for aluminum shock collars for them. I cant seem to find the Pro 4 ones anywhere can someone tell me whose aluminum shock collars will fit on this car and who has them in stock.
Jonathan Sohl aka Chicken Little
SMC-Racing/PT Racing Oils/TQ Racing Wire/
Sohlman113 is offline   Reply With Quote
Old 08-13-2009, 07:29 AM   #940
MD
MD's Avatar
Trader Rating: 104 (100%+)
You could call or email HPI and ask if the Sprint 2 shock caps would work. They may know what shock caps would work.
MD is offline   Reply With Quote
Old 08-13-2009, 02:34 PM   #941
mr fit's Avatar
Try www.rcmushroom.com
Old 08-15-2009, 02:01 AM   #942
Default max spur size (trying to get motor to fit)
Hi there. Whats the max (48pitch) spur I can fit??
Im having issues with fitting a brushless motor.
1101 is offline   Reply With Quote
Old 08-17-2009, 10:47 PM   #943
Trader Rating: 4 (67%+)
I'm new to electric actually at this pomt I don't even own anything electric but I'm wanting to get into carpet racing. I've been looking at the cyclone rtr since I'm not really sure carpet is what I want to do. I'm just wanting to race in a 17.5/27t class. Is the cyclone rtr as upgradable as hot bodies makes it out to be? Can the chassis be upgraded say to the tc chassis on down the line? For a beginner is it even a fairly competitive car to start out with? Any help or input would be great!
Hot Bodies D8-future home of a novarossi plus 4(courtesy of H.E.S.and Monty)-DS1015-spektrum dx3r/Team Terribles
Shane369 is offline   Reply With Quote
Old 08-18-2009, 07:26 AM   #944
vazzo's Avatar
YGPM dude!
Old 08-18-2009, 08:52 AM   #945
MD
MD's Avatar
It's a very good competitive car. You can go to Hot Bodies web site and see the various hop ups that they offer. 3Racing makes hop ups for it. I know you can get graphite shock towers, cvd's, a one way, a solid axle, but I don't know if you can get a graphite chassis for it. You can email Hot Bodies and ask them.
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
