Tub Cyclone `S`
#886
GasGod - I didn't have any issues with the chassis. I had two issues. The steering turnbuckles are small and tend to pull out of the ball cup. I have broken one or two steering knuckles. When you buy the knuckles you get one steering knuckle and one rear hub. So I have got a few extra rear hubs.
thnx I will pick up some for spares-(are there better ones avail?not alum.)turnbuckles I will replace on assmbly-I like captured ball end anyhoo-Anyone else have any probs?I need all the help I can get-lol
#888
Well, that's why i am asking about with this Reedy 5000, not only but also the coming soon all new LRP 5300 and Robitronic 5000, they are also heavy and good performance but with the same problem, so much tall which will not fit so much "S".
Thanks anyway!
Well there's another question could anybody tell if tried before "LOSI's LCD".
How was it?
I tried asking in HB Cyclone thread before, but without any answer.
Best regards
#889
Really, maybe even could try also that "PPDBILLET" 3.0 oz base weight pad(picture below) to gain more CG.
Thanks anyway!
How was it?
Best regards
Thanks anyway!
How was it?
Best regards
#892
About to replace 3racing 1, i prefer to modifying the original.
Thanks!
#893
Hi guys,
Just received the Cyclone S with a lot of upgrades that i bought on ebay. Im very happy because all the seller published was true, the car its NEW and UNUSED. All the upgrades mentiones were inn, and the stock parts were on a separate bag.
The thing is that comes with center pulley 18T, how thats affect the pinion and spur selection ?
I ordered a couple of pinions and spur from Kawada based on gearchart.com, pinions 32, 34 and 36 and spurs 66, 68 and 70
I assume the tranny ratio from gearchart.com its considering stock 16T central pulley ... so i dont know if the pinions and spurs i bought will work good or not with the 18T pulley.
This car will be raced on 13.5 brushless (novak) and 6 NiMH batts (maxamps 4.700mah)
thanks,
thanks,
#894
Hi guys,
thanks,
thanks,
16T Pulleys = 2.4375
18T Pulleys = 2.1666
I sent a number of requests to the hosts of gearchart and they never add the new cars, I think they have stopped developing the site or something. Anyway most manuals give you the gear ratio these days.
Cheers
Adrian
Cheers
Adrian
#895
Hey guys,
I am running the stock 96t 64p spur and was wondering what pinion i should use for a 19t motor? I'm not used to gearing with 64p gears so I really have no clue thanks for any and all help..
Phil
Phil
#896
try 35-38 you should shoot for a fdr of 6-6.5 gearing always depends on track-ask others what fdr they are running--
#897
Missed the Fed=ex guy today--My kit should be here tomorrow-gonna build it tomorrow test thurs or fri- and race Sat--13.5 /rubber outdoors lol Hope the front end holds together as I have no spares yet.Gonna try some other brand uni's or cvds-I have some that measure 44mm so-- gonna give it a shot.I have seen the dogbones chew up an rtr's axle stubs badly,they would actually lock up the front wheels in a turn--
#898
Hey there, just got myself a cyclone S I've never ran on road before so I need help.
FYI I plan to run Trinity 5000 Lipo's on asphalt
1. Gearing for a 17.5 or 10.5 Pinion and Spur pls not just Final drive (Starting point anyway)
2. Basic idea of suspension starting point - springs, oil, piston
3. Sway bars
4. any tips pointers to consider before going racing.
thanks in advance
3. Sway bars
thanks in advance
#899
bummer snapped 2 chassis in a week--both at the same spot and no hits--
