Old 04-08-2009, 03:54 AM   #856
vazzo's Avatar
Trader Rating: 100 (100%+)
Originally Posted by YBR View Post
Thanksfor the info!!! Any must haves for this car?
Everything Pat got in his deal above mate, upgrade the centre layshaft to steel with metal pulleys as well, the stock ones strip if you run anything faster than 540. The shocks are ok, I would upgrade to pro4 or Tamiya TRF.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 04-08-2009, 10:57 AM   #857
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi guys,
just a question while im waiting for my cyclone to arrive ... wich pitch they use on the spur and pinion ?, 48p or 64p ?, i have to buy pinions, i will be racing 13.5 brushless ...
thanks,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-08-2009, 11:19 AM   #858
YBR
64p. Thanks everyone for the help!!
Phil
YBR is offline   Reply With Quote
Old 04-08-2009, 12:03 PM   #859
Tabushi's Avatar
Phil
Can you give me guys a number of teeth on pinions and spurs to buy while my car arrives ?, i mainly will race on this track, sometimes they put very technical layout and other times like on the video, very wide open layout (this video is from GT class but on the same track, im the black nose orange rear body ) : http://www.vimeo.com/3536193
Remember, 6 cells 13.5 brushless ...
thanks,
Pat
Old 04-09-2009, 05:20 AM   #860
vazzo's Avatar
thanks,
Pat
Gday Pat
Novak recommend an FDR of 4.5 for the 13.5 with a sintered rotor. So if you go to www.gearchart.com you can find the exact combo to run. If your running the cyclone S with the standard 16t pulleys then the gear combo to run would be around a 70 spur and 35 pinion which will give you an FDR of 4.88, check temps after 2 mins practice and gear up or down accordingly by changing the pinion, you should be coming off at about 80 degrees celsius after 5mins. I would honestly run 48 pitch gears mate they are easier to work with.
Cheers
Adrian
Old 04-09-2009, 02:31 PM   #861
Tabushi's Avatar
Originally Posted by vazzo View Post
Gday Pat
Cheers
Adrian
Thanks a lot man !!
Im all new to electrics so that speech about 64p v/s 48p its totally unknown to me and im learning. What do i need to "transform" the stock 64p setup to 48p ?, and ... what would be a good setup to start on this car on 48p ?
thanks,
Pato
Old 04-09-2009, 07:25 PM   #862
Tabushi's Avatar
Thanks guys for help on gearing, im looking now to buy online 69 - 70 - 71 spurs on 64p and 34 - 35 - 36 on 64p pinions ...
The problem is that all the online stores i know only have 90+ teeth 64p spurs !!!, whre can i get lower numbers ?
Now, if i buy 48p spurs and pinions, will be fit ok ?, if so, wich configuration would be good for 13.5 brushless ?
thanks !
Pat
Old 04-09-2009, 07:40 PM   #863
MD
MD's Avatar
Trader Rating: 104 (100%+)
Tower Hobbies has the following:
Kimbrough 64p - 88t
Robinson 64p - 73T,75t, 78T, 88T, 81T
MD is offline   Reply With Quote
Old 04-09-2009, 09:40 PM   #864
GasGod's Avatar
Default Stock driveline
Planning on running 13.5 and lipo-Will the stock driveline(outdrives,pulleys,ect.) of the cyclone-s hold up?Don't have a lot of $$ and the price on the tub kit is VERY attractive.Track is asphalt outdoors w/rubber tire. Or would 17.5 be a better choice. thnx-
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 04-09-2009, 10:06 PM   #865
k
I've been running my cyc S with a 19 turn motor and 6 cells for 3 months now with no problems on a carpet track. I did have to put a thicker spacer on the center shaft, but that was a $.75 mod. The rest of the car is stock. It's always fun when you spank a few high dollar cars with a $129 plastic cyclone!
jay272 is offline   Reply With Quote
Old 04-09-2009, 11:00 PM   #866
Tabushi's Avatar
Originally Posted by jay272 View Post
k
Last year i was living in Colombia, and they race 19t / 10.5 brushless class, and the top drivers are racing Cyclone S cars on asphalt ... high dollars drivers put strange faces when they get passed by US$ 150 car
cya
Pat
Old 04-09-2009, 11:02 PM   #867
Tabushi's Avatar
Guys,
this would be a good choice of pinions and spur to buy for 13.5 brushless 6 cells racing ?, its the best i found and lower on spurs, used the gearchart creator online to find a 4.5 around spot ...
thanks,
Pat
Old 04-10-2009, 08:19 AM   #868
V_28's Avatar
Hi guys/gals,
Purchased a Cyclone S RTR a few weeks ago as a spare to practice on and have a question I hope you can help me with? It came with the Jolt+R ESC and I was wondering what turn motor this can handle? I've looked on the net without much luck.
thanks in advance
V_28 is offline   Reply With Quote
Old 04-10-2009, 10:39 AM   #869
YBR
Alright!! I got my Cyclone S ordered from Speedtech so it should be here in a few days. Can't wait to start racing touring cars again. Have not raced those since they became popular in the early 90's. Probably going to run it stock for awhile, then upgrade, would you guys recommend starting with the drivetrain or suspension? I will only be running in the stock class.
Thanks,
Phil
Old 04-10-2009, 10:54 AM   #870
Suspended
nice lookin car
09 lex 250 is offline   Reply With Quote
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
