Old 08-26-2008, 05:50 AM   #781
mangoman's Avatar
Originally Posted by timmaay View Post
im trying to get more steering and installed 4mm shims in the servo saver. upon doing this the steering has binded up against the pivot block. is there any way to get around this problem?
thanks!
Yes dont use the shims....
The plastic steering already has ackerman built in.
I dont think its 4mm but its definitely more than standard.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 09-06-2008, 11:15 AM   #782
TwoTone's Avatar
At some point I saw a link to a shop selling these for $125.00. Does anyone know which store that was? I'd like to get one for my son.
TwoTone is offline   Reply With Quote
Old 09-06-2008, 11:30 AM   #783
slakr's Avatar
Trader Rating: 25 (100%+)
Ultimate Hobbies... but they are "out of stock"
http://www.ultimatehobbies.com/istar...=HBS66446!1007
http://www.ultimatehobbies.com/istar...=HBS66403!1007
The RTR is in stock, but it is $199
http://www.ultimatehobbies.com/istar...=HPI66402!1007
XRAY XB2, XT2 ~ TLR 22-4 2.0 ~ Mugen MBX7TR Eco ~ JQ THE eCar WE, THE Car WE
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 09-06-2008, 11:53 AM   #784
TwoTone's Avatar
Thanks alot
Old 09-30-2008, 05:27 PM   #785
Trader Rating: 18 (100%+)
Hi, i have a cyclone s rtr and want to convert it to a drift racer. I was hoping someone could tell me a good drift set up for this car.
Thanks, Rhys.
speed freak is offline   Reply With Quote
Old 09-30-2008, 08:10 PM   #786
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi guys,
It a good idea to use the Cyclone Tube S kit to race 13,5 brushless + NiMH or Lipo class ? (rubber tyres, asphalt)
thanks,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 10-23-2008, 09:40 AM   #787
crazy4wdracer's Avatar
Send a message via AIM to crazy4wdracer
Why isn't the Cyclone S Kit in stock at ultimatehobbies.com or speedtechrc.com? They haven't had the kit w/o or with the body in stock for a while. Anyone know why? I wanted to buy one from one of these sites since they are much cheaper than Tower Hobbies. Anyone racing the Cyclone S in Vintage Trans Am?
crazy4wdracer is offline   Reply With Quote
Old 10-23-2008, 10:21 AM   #788
MD
MD's Avatar
Trader Rating: 105 (100%+)
crazy4wdracer- Tower may be the best deal right now. Because, you get $20.00 off an order of $149.00 or more. I ran the Cyclone S in a six cell vitage class with the HPI Mustang body and the speed was very good, but it was loose. I ran out of time to get it hooked up.
MD is offline   Reply With Quote
Old 10-23-2008, 10:25 AM   #789
Thanks, I didn't realize tower had the $20 off coupons. Were you racing on asphalt or carpet?
Old 10-23-2008, 10:49 AM   #790
MD
MD's Avatar
I was racing on asphalt. Your welcome.
Old 10-23-2008, 12:32 PM   #791
M-Tune's Avatar
Default Cyclone S help
What pinion size is a good starting point for the Cyclone S with a LRP Brushless 5.5 motor?
M-Tune is offline   Reply With Quote
Old 10-23-2008, 12:52 PM   #792
MD
MD's Avatar
M-Tune - I don't really know since I run stock,but you may want to check some of the setup sheets for the regular Cyclone.
Old 10-23-2008, 01:55 PM   #793
mangoman's Avatar
A 5.5 might be a little fast for a stock Cyclone S. Keep an eye on your diff halves and the center pulleys.
Also if you run a spool up front you will need an aluminium center pulley for the front belt, which also means changing the layshaft.
Also make sure you have changed out the C hubs to the proper carbon graphite ones. The stock plastic ones are rubbish and will literally break in your first few runs.
With the gearing you should ask around but i think what you posted in the main thread sounds right might be a touch high for a starting point though.
www.smaracing.org
Old 10-24-2008, 11:01 AM   #794
mr fit's Avatar
the best c hubs are the aluminum ones. i bought mine at rc-mushroom.(or you can buy them at 3 racing.com) they have 0-2-4 degree hubs.i also bought the aluminum knuckles for the front and rear.the car is as strong as a tank now. and the weight is the same as the plastic ones.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 10-24-2008, 11:21 AM   #795
mr fit's Avatar
are you running on an outdoor 1/8 scale or nitro 1/10 scale track? i have ran 10.5 on an outdoor nitro track. it was plenty fast. i think 5.5 might be too much and hard to control.you might not get the best out of your ride.then again if you are running on a big 1/8 scale track try a 30 pinion and work from there. you may want to go up or down in pinion size.also change your spur to a 103 or 108.you can check andy moore's setup sheet for reference. check motor temps frequently. make sure they dont pass 190.sometimes after you stop, motor temps go up as all the heat builds up inside and not being vented.try not to burn your motor.
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
