Old 07-26-2008, 04:58 PM   #766
MD
MD's Avatar
Trader Rating: 104 (100%+)
I need help with the Cyclone S. It is very difficult for me to set up. I have owned many, many touring cars. I have never had a car that wanted to swap ends so much. It constantly over steers. I have the rtr version and one with with some hop ups. I have done everything i can think of. I have used softer springs in the rear, harder in the front, light weight oil in the rear shocks, heavier oil in the front shocks, toe out, ride height and droop adjustments, I have used the stock tires, have used other brands of good rubber tires, vintage tires and rims, moved shock positions, adjusted the steering throw on my radio, etc. I cannot get it really grip in the rear. I have owned a pro 3, pro 4, XXXs, TA05, TC3, RDX, and others. I must be doing something wrong.
MD is offline   Reply With Quote
Old 07-27-2008, 02:46 AM   #767
mangoman's Avatar
Are you sure the front center pulley is not stripped?
The plastic can strip if you use a one-way or spool so if you give it acceleration it looks like the wheels are spinning but if you hold the wheels and spin the spur manually you will see it doesnt really have drive.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-27-2008, 07:17 AM   #768
MD
MD's Avatar
Mangoman - I don't think so, but i will check it out. Thanks for the help.
Old 07-27-2008, 09:01 AM   #769
slakr's Avatar
Trader Rating: 25 (100%+)
Originally Posted by slakr View Post
I bought this Cyclone Front Solid Axle (Spool) for my Cyclone S
https://www.ssl-stormerhobbies.com/c...ns&pn=HOT61045
But the stock Cyclone S dogbones don't push far enough into the spool outdrives.
Are there other parts I need to put a spool in my Cyclone S?
Thanks.
Anyone?
AE B6D,TC7|Mugen MBX7TR Eco|JQ THE Car WE,eCar WE
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 07-27-2008, 02:55 PM   #770
MD
MD's Avatar
The stock Cyclone S comes with gray foam inserts for the diff out drives. Did you put those in? If they are still too short, you'll probably have buy the optional cvd's.
Old 07-27-2008, 03:50 PM   #771
slakr's Avatar
Actually, the pins or ears on the dogbones don't slide into the spool outdrive past the beveled portion of the slots on the outdrive. It is as if these pins or ears are to big or the slots in the spool outdrive are to small. Can't even get the dogbones in far enough to stand the tires straight.
Old 07-28-2008, 01:37 AM   #772
mangoman's Avatar
Slakr that is more than likely possible due to the following.
There are v1 and v2 universals. The difference is that the the sphere on the end of the v2 universal where the pin is fixed through is slightly smaller. So it might be the size of that stopping you from being able to put the dogbone into the cup.
Personally i never tried using the dogbones on the S i also found when putting them into the cups on the ball diff that they were binding a touch in the first place and i didnt like them. I ditched them and went for universals.
If you are looking at getting universals 3 racing make some which are cheap but they can break easily if you are using a spool/oneway (but they will be just fine in the rear). I always use the HB Steel HD Universals (v2) up front because they are the strongest available but can sometimes be hard to get. Then i have some older aluminium ones which i use in the rear cause they are a little lighter and they came with other kits that i had.
If you are racing anything faster than stock i would personally recommend getting the steel hd unis
www.smaracing.org
Old 07-28-2008, 05:58 AM   #773
slakr's Avatar
Nope... nothing fast. Right now the Cyclone S is a dedicated USVTA racer; 21.5BL motor.
Old 07-28-2008, 08:32 AM   #774
mangoman's Avatar
BTW you know you need to upgrade center pulley to a metal one if you are using spool....
Only need to do the one to the front belt but it also means you will need to get a new layshaft. Depending on whether you have the old or new layshaft you may be able to continue using a plastic center pulley to the rear belt
www.smaracing.org
Old 07-28-2008, 08:51 AM   #775
slakr's Avatar
Yep... I did both center pulleys, spur gear hub and center shaft
Old 07-28-2008, 11:05 AM   #776
mangoman's Avatar
That's good. Although im thinking that with a 21.5 BL i expect that a one-way would actually be faster than a spool.
You may want to ask around the track you are at and see what the fast guys in your class are using up front.
www.smaracing.org
Old 07-28-2008, 11:09 AM   #777
Taffyjnr5's Avatar
Trader Rating: 30 (100%+)
Hi,
I am about to set my 9yo son's Cyclone S up with a 21.5.............
Serpent ERYX 4.0
Sworkz EVO LE/OS Speed
Sworkz EVO 2/Hobbywing
Taffyjnr5 is offline   Reply With Quote
Old 07-28-2008, 11:38 AM   #778
slakr's Avatar
I am pretty consistant in the top 3 with my T2R and I use a spool up front. The Cyclone S is just going to be a second VTA car to have around and to lend out to try and get more onlookers interested in the hobby and class.
There should be a few guys at the race this weekend with Cyclones. Maybe they have some different dogbones (aluminum, V2 Etc.) as spares that I can see if they fit into the spool I have. I might pick up an extra set of the Cyclone S bones (they're cheap) and shave a little off the pins/ears so that they move freely in the slots of the spool outdrives.
Thanks for all the comments/suggestions.
Old 08-21-2008, 07:57 PM   #779
Well I am a new "S" owner,getting back into racing after a couple of years off. All I can say is what a insanely easy build this car is! Even after reading thru this thread I still had to scratch my head when trying to attach the diff mounts to the chassis, funny they didnt fix that typo yet! Anyways, any suggestions would be welcomed and I plan on setting it up for the T/A class.
boyntoncyclone is offline   Reply With Quote
Old 08-26-2008, 03:35 AM   #780
im trying to get more steering and installed 4mm shims in the servo saver. upon doing this the steering has binded up against the pivot block. is there any way to get around this problem?
thanks!
Cheese City Xtreme Rc
-Tim
timmaay is offline   Reply With Quote
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
