Old 08-04-2007, 11:14 PM   #586
mangoman's Avatar
Ive never seen any motor run as high as 51mm what type of stock motor are you running.
Ive only ever seen a 540 motor run as high as 48mm. I strongly suggest against using something that big if you are using one of the normal mainstream motors like a komodo or co27/x stock CarlosG you should ask around at your track which motor is most suitable and what the suggested rollout for that motor is. Different motors can have wildly different rollouts.
The rollout can then be effected by other factors such as track size, driving style and even your speedy (the variation would normally be around to -2mm to +4mm)
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-05-2007, 02:14 AM   #587
bullfrog_racer's Avatar
Angry
Our rules state we must use, a Standard 27Turn motor no variations such as RZ etc (the silver can type you get in basic car kits), most guys at our track use a 51mm roll out, if you dont you just cant keep up! I realize this wouldnt be suitable for most tracks but works well on ours.
bullfrog_racer is offline   Reply With Quote
Old 08-05-2007, 10:46 AM   #588
mangoman's Avatar
Ummm, Are you saying you use a standard silver can which comes in a car kit? (IE. A tamiya kit silver can motor?)
www.smaracing.org
Old 08-05-2007, 11:47 AM   #589
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
The only problem is that tc died here for now, and i was just needing a starting point so I can figure it out from their.
Also tried to calculate the pionion required to run with my spur for that rollout and their is no room for a pionion with my spur that I am using to run that rollout. I had posted the same question in the other cyclone thread and was given a starting point.
CarlosG. is offline   Reply With Quote
Old 08-05-2007, 11:35 PM   #590
Deves's Avatar
Hi ya'all I've got a small problem maybe someone here can help. I installed a novak 13.5 brushless system in my cyclone and i'm trying to get a FDR of about 4.5 to 5. in 48 pitch for asphalt racing. What spur/pinion combo should I use that will fit in this car? Right now I have a 77 and 78t spur gear. I thought about trying a 72t spur Thanks for any help/ideas you have.
Deves is offline   Reply With Quote
Old 08-06-2007, 02:55 AM   #591
Thats right.
Old 08-06-2007, 06:53 AM   #592
CarlosG.'s Avatar
Try pinions 42t (4.5 fdr) to a 38t pinion (5.0 fdr) with your 78t spur.
Old 08-06-2007, 08:34 AM   #593
vazzo's Avatar
Trader Rating: 100 (100%+)
Hi Bullfrog
That link is for the cyclone not the sport version plastic tub chassis. You also referred to the silver can as 27t, the silver can is normally a johnson 540 or an RS540 mabuchi thus the reason you have such a high roll out, if you were to run a 51mm on a 27t stock motor it would cook lol normal rollout is low to mid 30's, then high 30's to low 40's for brushless. Anyone running brushless in the cyclone S will probably want to buy the motor mount specifically designed for brushless motors.
It would be great if we could share setup sheets for the cyclone S for various circuits.
Ill try and post one for my local track.
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-06-2007, 09:49 PM   #594
Deves's Avatar
Carlos will those fit with a 78?
Old 08-06-2007, 10:19 PM   #595
CarlosG.'s Avatar
I don't know. I have not ran 48p gears since my Xray T1 EVO. I have a 108t 64 pitch spur in my car right now. I could not get the 96t 64p spur to work with the pinions I had. I had to get a 35t pinion just to make contact with the 108t spur. I have the car originally box stock, except for the c-hubs and hub carrier so the motor mount is limited in how far the motor moves toward the spur and away from the spur. You will just have to try and findout by trial and error. Sorry, I could not be much of help to you on that question.
Old 08-07-2007, 02:51 AM   #596
Smile
Originally Posted by vazzo View Post
Hi Bullfrog
Cheers
Adrian
Cool, thanks for the info, am pretty new to RC but am having fun. Learning heaps, I posted the link as some of the info to me still seemed interesting and it was a bit of a random find so thought I would share. Cheers
Old 08-07-2007, 07:00 AM   #597
mangoman's Avatar
Hi Bullfrog
That link is for the cyclone not the sport version plastic tub chassis. You also referred to the silver can as 27t, the silver can is normally a johnson 540 or an RS540 mabuchi thus the reason you have such a high roll out, if you were to run a 51mm on a 27t stock motor it would cook ....
Cheers Vazzo yep answered what i was wondering about.
With the stock motors CO27s probably gear to maximum 29-30mm unless its a humungous track an X Stock gets geared a couple of mm higher if im not mistaken. But always better to start at the low end of the range and then gear up.
www.smaracing.org
Old 08-07-2007, 10:06 AM   #598
Manny's Avatar
mangoman, can you give us an update on the 3racing motor mount? Were able to stop the bearings from binding?
Manny is offline   Reply With Quote
Old 08-07-2007, 11:18 AM   #599
rc-zombies's Avatar
hey Manny..
have you finally shelved the Pro3 and got a cyclone?
Old 08-07-2007, 11:35 AM   #600
Manny's Avatar
Hey RCzombies,
I still race the Pro3 ( I like being six years behind in technology) but i picked up a Cyclone S to tinker with. I think the all plastic chassis should be fine for 540 parking lot racing.
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
