Tub Cyclone `S`
#451
Originally Posted by turtle
What size grub screw(s) do i need?
Sorry for all the questions, its just I want to order all these peices in one hit.
#453
Cyclone S + Pro 4
Hey, can you guys tellm eis the PRO4 almost the same as the CYclone S, ie share alot of the same parts and design?
#454
Mainly suspension parts. Arms, knuckles, hub carriers.
The wheel axles should be the same but not the cvds.
Pivot blocks are the same but not the FF RR blocks. Although if you have a cyclone S you should upgrade the tub to a CF deck if you want to use pivot blocks and you will also need washers to shim the arms properly.
#458
Originally Posted by vazzo
Hi guys
I just wanted to see if anyone had replaced the plastic bushings in the steering on the Cyclone S? If so what size bearings did you use? I bought some and they are a tad to big.
Here are the ones I used in my S.
http://www2.towerhobbies.com/cgi-bin...?&I=LXD101&P=7
#459
Originally Posted by mangoman
Where do the FF/RR blocks work? If im not mistaken they are not the same as zero degree pivot blocks.
Cyclone S RR is 3.0, same as Pro 4/Cyclone alloy ones.
Anyway, my '3R Edition':
My Cyclone:
Body here.
Chassis:
Any Q's, just ask.
#460
#462
Labelled on a Pro 4:
FF - '2.5' (Usable on Cyclone/S)
FR - 'F/R' (Not usable on Cyclone/S)
RF - 'R/F' (Not usable on Cyclone/S)
RR - '3.0' (Usable on Cyclone/S)
For some reason, the carbon HB and 3R chassis' have holes drilled and countersunk for the 'F/R' and 'R/F' pivots, but as padailey says, the belt rubs on them if you use them. Hope this clears things up.
#463
Low friction belt
#464
Ok just to clear things up with the suspension mounts. With regards to FF RR i mixed these up with what the Pro 4 uses as F/R blocks. Infact there is not really any such thing as an FF RR block as FF and RR blocks are the same. I assume they are labelled as FF RR on the Cyclone S so people can easily identify which block should go on the front and which on the rear. Especially since you really dont want to have a zero degree pivot block on the rear of your car.
When taking the parts of the pro 4. The pivot blocks (the 2.5 and 3.0 degree blocks) can be taken and fitted to a cyclone. However, it is not recommended that you fit the aluminium pivot blocks to a plastic tub chassis as i believe this places stress on the chassis and can snap it (at least thats my reasoning for why my chassis snapped).
Further to this if you use the aluminium pivot blocks (ie 2.5 3.0) you will need to take the pivot balls from the Pro 4 kit (the Cyclone S does not use pivot balls) and you will also need to get two 3x6x0.75mm shims for each pivot block.
If you upgrade to aluminium F/R R/F blocks on the cyclone S, again you will need the two pivot balls and two shims for each F/R or R/F block. However, for the F/R and R/F block you instead require thicker shims of the size 3x6x2mm.
Sorry for all the confusion and i hope the above is correct.
#465
WOW!
I'm pretty impressed with my Cyclone S, I lined up on my first race day against about as much carbon fibre and alloy at the tour de france! I thought I would get toasted with my plastic tub chassis Cyclone S as I was up against Yoko's tricked out TA05's TC4's etc. I won my first 3 B-Grade races and made the A final, I started 6th and if I had of avoided putting the car on its lid in the final few laps would have got 4-5th!. The only changes I have made so far was to locktite the diffs (which didnt budge all day after that!) and ran some Sorex 28R tyres.
I am now keen to complete a few upgrades 1st I am going to do front universals and cups, any other suggestions??
Cheers
Cheers
