Old 11-25-2006, 11:54 AM   #346
padailey's Avatar
I have the upper and low chassis from 3 racing and everything went together fine.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 11-25-2006, 09:35 PM   #347
kwellst's Avatar
Send a message via AIM to kwellst
ok i was just making sure that the carbon fiber was made right unlike the aluminum was. i'm just hoping that the knuckles, c-hubs, and rear-hubs are right.
Associated RC18B
kwellst is offline   Reply With Quote
Old 11-25-2006, 11:15 PM   #348
TcEcho's Avatar
Send a message via MSN to TcEcho
I have been using the knuckles for a few weeks with no issues. They fit just like the stock ones did.
TcEcho is offline   Reply With Quote
Old 11-26-2006, 08:33 AM   #349
well i just ordered c-hubs,knuckles, and rear hubs. so i hope that they fit. what about the CF bottom chassis, the CF upper deck, CF bumper support, and the CF middle chassis. i want to get those but dont know if i should.
I just installed the Woven Fibre (silver color) main, upper deck, front and rear shock towers from 3racing. First of all, the WF parts fitted exactly, and secondly, the car felt lighter and more nimble as compared to when I was on the stock chassis. I am very happy with the result.
Karmon is offline   Reply With Quote
Old 11-26-2006, 09:40 AM   #350
kwellst's Avatar
it will be more nimble, its lighter and its stiffer.
Associated RC18B
Old 11-28-2006, 06:50 AM   #351
mangoman's Avatar
Yeah (bxpitbull) im definitely not happy about these 3racing bulkheads. Ive now got genuine hotbodies bulkheads and spent about 2 hours earlier swapping them in and out with the 3racing ones.
There is definitely something wrong but i cant work it out exactly.
Using digital vernier calipers it looks like that it is ok but i think what is happening is the way they have been manufactured there is something catching on the sides and there is not enough room between the two bulkheads which squeezes the bearings up against the part which catches. That probably doesnt make much sense im hoping to post some photos later to explain what i mean.
I posted comments on the 3racing forum and they tried to say that plastic parts are inaccurate and I replied that if that were the case hot bodies might as well not make any plastic replacement parts because they were implying they could all be different.
It would be nice if 3racing could check it over and admit if there were some kind of problem and recall the parts if defective but i doubt that would happen. I would be interested in hearing from any other people that have the 3racing bulkheads?
Padailey how did you end up going with those bulkheads?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-28-2006, 02:58 PM   #352
padailey's Avatar
Well I never did have the 3racing bulkheads (maybe I wasn't clear on that) but I did have something in the drivetrain binding. I just kinda loosened things up and retightened and it got a little better. But the drivetrain had been tighter than I thought it should have been. I did get the 3racing diffs and universals and replaced the front (rears coming). Man what a difference... they fit great and really loosened things up! We'll see how they hold up... so far so good... had a very hard hit the other night and broke the top deck in 4 places and sheered off the steering linkage, but nothing else broke. I thought it kinda odd to break those pieces and nothing else expecially considering how bad the crash was. At least 3racing gives you different standoffs when you get the main chassis so I was able to go back to the "S" top deck.
So how do you check/fix if the chassis is tweaked?
Tamiya TRF416X
Old 11-28-2006, 04:24 PM   #353
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Parts Needed for Spool Set Up on Cyclone
He fellas, what parts will I need in order to run a front spool on my Cyclone? Can anyone please list them and their parts numbers so that I make sure to order them this week, ASAP. I'll be running brushless 4.5R as usual, so need the parts that can handle that power and more...thanks million!
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-28-2006, 04:27 PM   #354
yyhayyim's Avatar
Default Xray T2 Parts and Cyclone
FYI: Xray T2 front steering knuckles and hubs work nicely with the Cyclone. We have found them to be a bit stronger, too, and gives a bit better steering and ackerman.
Old 11-29-2006, 05:22 AM   #355
mangoman's Avatar
Dont know about the parts for the spool, i think with the new moore-speed edition there is not a third type of spool.
However, i had problems when i installed a front one way that the centre pulley to the front belt kept getting stripped. I think this was due to stresses from crashes and expect the spool could do the same thing.
If you are looking to upgrade from the plastic centre pulleys you need to get these:
1 x HB70743 (Direct Layshaft)
1 x HB70711 (Spur Gear Hub)
2 x HB70725 (16T Direct Pulley)
www.smaracing.org
Old 12-02-2006, 09:45 PM   #356
mangoman's Avatar
Oh, it looks like the centre pulleys dont come with grub screws.
So you need to add two of those...
www.smaracing.org
Old 12-03-2006, 07:53 AM   #357
kwellst's Avatar
if i got the CF topdeck, would i need some extra spacers to move the gap up?? i do not have the cf lower deck or any other chassis hop ups.
Associated RC18B
Old 12-04-2006, 11:52 PM   #358
mangoman's Avatar
The 3racing topdeck comes with washers but, as i have the bottom deck as well, I dont recall using them.
I assume you have a genuine HB Upper Deck but maybe this might help?
http://www.3racing.com.hk/manuals/cy-16.jpg
www.smaracing.org
Old 12-06-2006, 05:20 PM   #359
kwellst's Avatar
i dont think im gonna get the cf topdeck... i think im gonna get the alum bulkheads, middleblock, cf shocktowers, and the cf middle deck. and i might get the cf topdeck and bottom as the final 2.
Associated RC18B
Old 12-13-2006, 05:57 PM   #360
turtle's Avatar
Can someone point me in the right direction for what pinion/spur gears to use? I am just planning on running a 540 silver an for the moment. I read tat it might be better to go to 48 pitch rather than 64 pitch spur that some in the kit. Any help would be appreciated.
turtle is offline   Reply With Quote
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
