Old 10-28-2006, 09:05 PM   #271
padailey's Avatar
Thanks!
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 10-29-2006, 07:26 PM   #272
bxpitbull's Avatar
Default I AM NOT IMPRESSED!
Ok guys, heres the scoop! Cellshield with GTB-don't do it! It acts as a voltage restrictor, puts drag brake on the car; addressing that with Dimension Engineering on Monday. Now for the "new and improved" Cyclone...NOT IMPRESSED! Graphite main and upper chassis, aluminum outdrives by titanium racing (nice, no slippage), hara shocks, ball bearings where bushings came stock (spur, diffs) and GTB/4.5 81 spur/21 pinion FD 9.40...HPI slicks, 6000mah Li-po, belt tensioner and a few miscallaneous hop-ups.....car was slow! It looked like I may have hit 30 mph. Made this funny "whir whir whir" sound. Low end was weak, top end, not what I had with the Pro 4! With the Pro 4, I ran the same gear, with a FD of 9.23 and the car was an absolute rocket! So, what the heck is going on?!?!?!? Belts are tight without binding, free spinning drivetrain, so what the FKCU?
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 10-29-2006, 10:48 PM   #273
mangoman's Avatar
On mine with the kit setup the rear belt was too tight and i had turn the diff bearing holders around 180degrees to loosen it up. It was making strange noises too when it was too tight, dont know if this will help or not.
There are a couple of guys in australia running brushless on cyclones Ss and i think they reckon that the car is ok without the belt tensioner.
Also have you checked to see if you have stripped the centre pulley to the front belt (if you are still using the plastic centre pulleys). Although if this happens the car does really strange things and is uncontrollable on power in corners.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-30-2006, 08:56 AM   #274
bxpitbull's Avatar
It definately makes a funny noise. I have rotated the bearing holders and will continue to experiment. To say the least, I was expecting more. Nothing is stripped, plenty of feed to the wheels, just isnt fast. Smooth yes, but definately not what I was expecting. If this continues, I will have a Cyclone for sale.
Old 10-30-2006, 10:43 AM   #275
academygaz's Avatar
Originally Posted by academygaz
I'm in the process of making my S into a 3R edition.
I've ordered all the following bits from Dinball (both the shop and ebay store):
already here and fitted:
Alloy lower bulks F & R
Alloy S upper bulks F & R
Alloy motor mount L & R
CVD's F & R
FR Purple Pivot
RF Purple Pivot
Carbon lower deck
Carbon upper deck
Next on the list:
carbon towers
alloy diff halves
all the complete graphite corners from a Pro 4
FF & RR HPI Pivots
Pro 4 shocks
Then I'll be happy, and it'll still be cheaper than a black Cyclone!
Update, the carbon chassis has arrive, it looks awesome. I haven't measured it but it looks like its 3mm thick, ideal for carpet. Its also got little plastic stoppers to hold the cells in, but its tape only, no strap. The upside is its got a purple alloy ariel mount.
Also, the topdeck is here, its got its own standoffs and a neat '3' logo engraved above the centre servo saver.
Pics when fitted.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 10-30-2006, 12:02 PM   #276
bxpitbull's Avatar
Pics when fitted.
I hope your car runs and performs better than mine. Mine appeared to be rock solid, dialed and all that good stuff. All of the guys I race with were looking forward to it having "the speed of the pro4" but in belt form. Lets just say it didnt measure up. Outside of the purple bulkheads and motormounts, my car is pretty much hopped up to standard Cyclone status. Any suggestions??? And please, not the "adjust your diff bearing holder"...that has been done several times already.
Old 10-30-2006, 01:52 PM   #277
padailey's Avatar
academygaz.....did you get the SSG or woven chassis?
Tamiya TRF416X
Old 10-30-2006, 02:14 PM   #278
padailey's Avatar
Well just finished up the weekend at the Midwest Carpet Championships in Omaha running my "S" in the 4300 rubber class. Had problems with the dang dogbones in the front and before I got it figured out I was using yokomo bd knuckles cause I bought the store out of Pro 4 knuckles and broke them all. The yoks work but aren't a perfect fit which means you'll have to change out both fronts so they are the same (if you ever have the need). Basically the dogbone was coming out of the axle causing the knuckle to snap. Man was I frustrated. Also broke the chassis in a different place than before (battery side where the hole is cut out to put a driver through to tighten the motor screws). Boy after you look at that there isn't much support there! But by the end the car was awesome! bxpitbull I don't have any wisdom for your problem but I was running against T2's, RDX's, FT TC4's, JRXS's and I was hanging right with them when it came to speed. Hope you get it figured out!
Tamiya TRF416X
Old 10-30-2006, 02:49 PM   #279
bxpitbull's Avatar
Padailey, thanks. Hopefully, it's something I did wrong or overlooked that will work itself out to be a minor fix. I wanna to have some success stories for this vehicle. HPI/Hot Bodies need to snap out of it and get some support going. I mean honestly, how can you have Atsushi Hara, Surikharn and Andy Moore signed and not run one single ad (latest car action-one spread for the savage) for a championship winning car?!?!?!?
Old 10-30-2006, 06:06 PM   #280
kwellst's Avatar
Send a message via AIM to kwellst
why such a high FD bx?? i dont run brushless nor do i know enough about them outside the gearing has to be spot on. but a FD of 9.4 is alot of accel and no top end(for brushed motor). i run stock motors and i run around a 6.5 if i can on most tracks. i have not gotton my cyclone S yet, but its on its way. i was just curious why such a high FD. have you tried adjusting your diff holders?? JUST KIDDING
Associated RC18B
kwellst is offline   Reply With Quote
Old 10-30-2006, 06:15 PM   #281
bxpitbull's Avatar
For the 4.5, novak suggests a FD between 9.5- 10.5. These are the starting points and they say as long as your temps dont hit 160-170, you can actually go below that. With my Pro4 (same internal gear ratio), I ran a FD of 9.23 on 6000mah Li-Po for 35 minutes straight and never broke 130. Snappy low end and top end was flat out bananas. So, that being said, if the Cyclone is built on the same type of platform as the Pro4 but as a belted version, than I should have an absolute rocket, losing a hair of top end and having way more snap off the line.
Old 10-30-2006, 08:33 PM   #282
kwellst's Avatar
if it only ran 130(i dont know the outside temp when u ran it) and it now being colder i'd try for 9.0FD. and im sorry to hear that this car isnt like your pro4. the pro 4 is shaft drive correct?
Associated RC18B
Old 10-30-2006, 09:01 PM   #283
bigair78's Avatar
BX, how tight is your rear diffs? Mine was pretty tight and seemed to slow the car down. I loosened it up. I put it on the ground with the bumper on my shoe. I then tightened the diff until I found the sweet spot.
Are you running cvds or dogbones?
Josh
bigair78 is offline   Reply With Quote
Old 10-31-2006, 03:23 AM   #284
academygaz's Avatar
Regular 'black' woven. Where I race, the surface is a bit roughed up, so SSG turns black and nasty when scratched.
Fitting it today.
Old 10-31-2006, 09:02 AM   #285
padailey's Avatar
So is there any real difference between the two other than color?
Let us know how it all fits together!
Tamiya TRF416X
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 12:17 PM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 11:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 07:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 07:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 03:54 AM
SEO by vBSEO 3.5.0
