Old 01-28-2010, 08:59 AM   #1066
MD
MD's Avatar
Trader Rating: 105 (100%+)
When I modified my plastic, not very neatly by the way they are about even or flush. On the far left and right side the plastic bumper may stick out slightly. The hard bumper takes the hard hits.
MD is offline   Reply With Quote
Old 01-28-2010, 09:02 AM   #1067
MD
MD's Avatar
ozvena - In addition, I have recently found that Tamiya sells a bumper block of extremely dense foam that you cut to the size and you want. I may try that in the future.
Old 01-28-2010, 09:05 AM   #1068
ozvena's Avatar
MD, this is all very helpful! Do you have a link to that Tamiya bumper block?
ozvena is offline   Reply With Quote
Old 01-28-2010, 09:19 AM   #1069
MD
MD's Avatar
The Tamiya stock number is 53415. You can order it off the Tamiya America website and a lot of over seas sites have it. Here's a picture.
Old 01-29-2010, 07:35 PM   #1070
ozvena's Avatar
Do these stock plastic diff outdrives break? If yes, then I need some spares to keep around....
I am happy with the stock performance but if I am to get spares, would the aluminum last longer?
http://www.hotbodiesonline.com/piw.p...n&partNo=67724
I see that even the PRO diff is made of plastic, HB calls it space-age plastic and it seems that it is the same as stock, are they made from the same material and as durable as the stock?
http://www.hotbodiesonline.com/piw.p...=67720&lang=en
Thanks!
Old 01-29-2010, 07:53 PM   #1071
JLock's Avatar
Thanks!
I have never had any issues with any of the diff outdrives so far on both my Cyclone S and Cyclone TC. I will tell you if you have either car, upgrade the dogbone part of the CVD to the heavy-duty one. I have twisted several of the lighter purple aluminum ones but have not had that issue since changing over.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 02-02-2010, 10:19 AM   #1072
rko
rko's Avatar
Default help on FDR
hi guys,
does anybody knows if a 34/76(64dp) or 31/68(48dp) is possible on the cyclone s?
Aiming to get around 5.4FDR for the 'S'. Or any recommendations?
rko is offline   Reply With Quote
Old 02-02-2010, 10:40 AM   #1073
JLock's Avatar
Originally Posted by rko View Post
hi guys,
If you are running 64 pitch, to get near a 5.4 FDR (5.42), you need to run a 45 pinion/100 spur. I don't know what you need as far as pinion/spur if running 48 pitch. Your internal ratio on the Tub S chassis is 2.4375
Texas 5
Old 02-02-2010, 10:51 AM   #1074
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
hi guys,
76 spur wont fit with a 34 pinion.
Here are other options.
88/39
90/40
93/42
95/43
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 02-02-2010, 11:34 AM   #1075
rko
rko's Avatar
88/39
90/40
93/42
95/43
can i assume that they are 64 pitch? lets say for 88 spur, is 40 pinion possible. i'll prolly run min at 5.4fdr, but might push harder.
Old 02-02-2010, 11:40 AM   #1076
Super Moderator
charlie_b's Avatar
They are all 64 pitch. Im not quite certain what you mean by "push harder". Are you referring to handling? if so, there are ways to get steering out of your car...i run my S in RCGT Pro and 17.5 TC and doesn't lac in steering.
Old 02-02-2010, 03:54 PM   #1077
ozvena's Avatar
I have 88 & 47 and 47 is as small as it would fit without removing parts from the chases for a BL motors.
I was able to get 88 & 43 with a shorter brushed motor so no chases modification was needed but I needed to remove some material from the middle block. For a BL motor some material from the chases would have to be removed.
43 is as small you can do with 88 spur.
Old 02-02-2010, 03:58 PM   #1078
ozvena's Avatar
You can take 88 & 43 and calculate axle distance. With that you can check if your custom configuration would fit.
Old 02-02-2010, 06:46 PM   #1079
rko
rko's Avatar
meant that i might want to squeeze more top end out. aiming for 5.4fdr, but might go down to 5fdr.
Old 02-02-2010, 06:51 PM   #1080
rko
rko's Avatar
thanks alot. so the possible play are from a 43/88 to 47/88?
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
