Old 09-14-2009, 11:56 PM   #946
Default Front Spool/Differential
Hi,
Is there a way to just lock the front differential that comes with the kit, so that it acts like a spool?
I'm going to just try not adding the ball bearings and tightening it all the way down... has anyone tried this?
Thanks!
-AJ
spam77 is offline   Reply With Quote
Old 09-15-2009, 01:52 AM   #947
vazzo's Avatar
Trader Rating: 100 (100%+)
Originally Posted by spam77 View Post
Hi,
Thanks!
-AJ
I wouldnt waste your time trying that AJ as there is massive risk in snapping the diff screw if it's too tight, if you do decide to do it pick up the titanium option or Pick up a V3 spool with the 44mm HD steel uni's.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 09-15-2009, 11:41 AM   #948
JSeay's Avatar
Send a message via Yahoo to JSeay
AJ,
I think that you wold be better off with the actual spool kit for the cyclone, as well as the pro diff kit for the rear. I will bring mine out on Sunday if you are at DHW as I have the spool kit on mine and you can check it out.
On another note though how are you guys balancing your S left to right? Is useing two scales the only real option with the stock shock towers? I know on some of the touring cars there is a hole in the middle of the shock towers that you can run a string through and lift your car with to see if your car is balanced left to right.
†Tracks: SDAR San Diego Asphalt Racing/Discount Hobby Warehouse†
†Team HOLY Rollers† †www.socal-rc.com - Southern California R/C Forums†
†My Blog: http://majicmanracing.wordpress.com/†
JSeay is offline   Reply With Quote
Old 09-15-2009, 02:19 PM   #949
Originally Posted by JSeay View Post
AJ,
vasso and Jseay,
Yeah, was trying to avoid spending money on a spool. When I built the TC5 kit... in order to make a front spool you basically just skip putting the bearings in and tightened it down. I think I'll go ahead and gamble and go with the makeshift Cyclone-S spool... since I really don't want a front differential anyways, I can just try running that until it blows up... then get the spool kit.
The reason I bought a Cylcone-S was the smaller upfront budget involved... To see if I can make a competitive car from just the $160. So, I'll see how it works with as minimal added investment as possible. Although, I may not even be that good/experienced of a driver to even notice the subtleties between a makeshift/real spool yet or even the pro rear diff for that matter!
Thanks again!
-AJ
Old 09-15-2009, 02:25 PM   #950
JSeay's Avatar
AJ,
I think for the type of racing we are doing that the front diff will be fine, until your budget allows for something different.
Old 09-17-2009, 06:36 PM   #951
I have a "S" and I also tried to just tighten up the front diff to make a poor mans spool, and yes the diff screw did snap right at the head. It worked for about 4 or 5 races but snapped during a practice run. Looking for a spool now, everywhere I look they are out of stock!
boyntoncyclone is offline   Reply With Quote
Old 09-17-2009, 08:19 PM   #952
MD
MD's Avatar
Trader Rating: 112 (100%+)
My Atomic, R/C Warehouse, & Advantage Hobby are showing they have it. When I searched I used the stock number HBS61045.
MD is offline   Reply With Quote
Old 09-17-2009, 09:12 PM   #953
mangoman's Avatar
If you run a spool or oneway in the front you will need to upgrade the center pulleys to aluminium ones. This also means you need to upgrade the layshaft which holds the center pulleys.
You can probably get away with only changing the left center pulley (for the front belt) i think the current layshaft still has holes to put the plastic ones on, but i never tried it.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 09-18-2009, 07:16 AM   #954
Thanks for the heads up MD and Mangoman!
Now my next question, should I just go shopping for the TC kit and forget about upgrading?
I am going to jump into 17.5 RCGT with both feet. they strated a series here and I am going to do it!
Old 09-18-2009, 08:45 AM   #955
mangoman's Avatar
Dont know what RCGT is but if you are happy with the Cyclone S then i would stick with it.
Theoretically the tub chassis can give you more grip than the full spec car due to the flex. Although its always nice having a shiny new car.
www.smaracing.org
Old 09-18-2009, 09:07 AM   #956
Its just with the S version I am finding out that if you make one upgrade(spool) you have to make 2 more(pulleys and CVDs). I am thinking to get the car to where you need it, it might be better to get the race kit? I really like the S but getting it to where it needs to be...
RCGT is any touring chassis, 17.5 bl, realistic bodies(no race bodies) and realistic wheels and HPI x pattern tires(no slicks). Makes for fun racing, fast, and old chassis's are still competitive due to the tire limits.
Old 09-21-2009, 08:56 PM   #957
Default asphalt setup
Hi,
Does anyone have a starting point setup sheet for the Cyclone-S? Specifically for low or high traction asphalt.
Thanks for the info spool info... so, sounds like I have at least I've got 4 to 5 race days before I bust that screw... maybe i'll just switch it back to a diff after 3 races to see how I like the diff. I like the TC spool/diff combo thing maybe i'll get that when time's right.
Thanks,
AJ
Old 09-21-2009, 10:00 PM   #958
MD
MD's Avatar
spam77 - Probably, the easiest thing to do is to look at the setup sheets for the Cyclone and use that as a starting point. It will be easier to find one for low traction asphalt.
Old 09-22-2009, 06:41 AM   #959
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
I am running a Cyclone S. I also have a TC but is concentrating on my S because i want to show it can contend in expert RCGT with the other cars that are 3x more....
I am running the diffs front and back. I don't use a spool because i don't want to buy anything else for it.
Front:
Stock Silver Springs
70wt oil
stock plastic toe blocks
1 deg toe out
-1 deg camber
Shock Position:
top-3rd from inside
bottom-outside most hole
Rear:
60wt oil
Stock Plastic toe blocks
-1 deg camber
Shock Position:
top-3rd from inside
bottom-middle hole
Stock Dogbones front and back.
I run the diff regular because i don't like the initial push the spool give the car. The spool does have more rip coming out of the turn, but with low traction surfaces as well as RCGT class, the diff works perfect. I probably wouldn't run a diff for mod, but for 17.5 and 13.5, diff should be fine.
I TQ'd this weekend by 2 laps and a half in a 7 minute race. I forgot to put o-rings back when i cleaned the front diff cups for the main so the dogbone popped out in front while steering on power. Otherwise, i ran away with it.
ANyway, you really do not need to spend the $$ if you don't have to. I even used Xpattern D comps and worked like a charm. Best of luck.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 09-22-2009, 12:23 PM   #960
JSeay's Avatar
Charlie,
That's good setup info. I think that all to often I am obsessed with getting the latest carbon graphite car parts and may be looking at the wrong things when it comes to running my cars. Speed is a result of car setup and the ability to drive. No amount of money spent on hopups or carbon parts is going to make me faster if I don’t understand why I am putting them on and what impact they should be having on the car.
Better to wait until I can recognize a deficiency and then upgrade that part, as at that point I will have exceeded the capability of the part/car with my driving, and will better understand why I am doing it.
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
