Old 01-05-2009, 06:14 AM   #826
MD
MD's Avatar
Trader Rating: 112 (100%+)
I guess the advantage to aluminum is that you can keep going if it's bent in a crash. If the price is right why not try it. I think I will.
MD is offline   Reply With Quote
Old 01-05-2009, 06:47 AM   #827
d1nzfe's Avatar
do anyone know if the 3 racing carbon upper deck fits the cyclone S without changing the chassis??
d1nzfe is offline   Reply With Quote
Old 01-05-2009, 08:06 PM   #828
Trader Rating: 17 (100%+)
I purchased a cyclone S kit this morning from speedtech RC
Now I am in the market for a Motor and ESC, perferably 17.5 brushless
Can some people please give me some opinions as I do not know much about choosing the proper motor (I can't really find any threads explaining this, I looked)
The car will be used mostly for fun, then I may try and get into some racing later on as I get a bit better
thanks
Mike
pantherblack is offline   Reply With Quote
Old 01-06-2009, 02:07 PM   #829
anyone???
Old 01-06-2009, 03:10 PM   #830
MD
MD's Avatar
I don't know much about brushless, but the Novak Havoc 17.5 is a reasonably priced system. it seems to be good for fun driving and club racing. You can go on Novak's sight and check it out.
Old 01-06-2009, 08:05 PM   #831
vazzo's Avatar
Trader Rating: 100 (100%+)
thanks
Mike
Gday Mike
I run the LRP TC Sphere and the Novak 17.5 in stock class it goes pretty good.
Good luck.
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 01-12-2009, 08:14 PM   #832
rcdude8's Avatar
Hi
I have a got bought a Cyclone S form speedtechrc and have already decided on my electronics. Does anybody know though where I can get the parts for the car in Australia and more specifically Brisbane or (if that is too refined) Queensland?
Also if someone knows a good gear ratio for 540, that would be helpful too.
Hot Bodies Cyclone S
LRP A.I. Brushless Reverse Digital
Acoms Technisport 2.4 Ghz Radio System
Mazda/Stratus Cross Body
rcdude8 is offline   Reply With Quote
Old 01-16-2009, 11:13 PM   #833
M-Tune's Avatar
Default Front Pivot Block Question?
The Stock Front pivot Block is a 0. What does it effect when you change it to say a 1.5 pivot block up front.
M-Tune is offline   Reply With Quote
Old 02-16-2009, 10:53 PM   #834
M-Tune's Avatar
Default Cyclone TC Chassis
Does the Cyclone TC Chassis mount up to the Cyclone S parts. or are they not compatible.
Old 02-16-2009, 11:19 PM   #835
Errm I know this is one month late, but changing the front pivot block will give more front sweep (aka inboard toe-out). fitting a 1.5 block gives the front 1.5 degrees of inboard toe-out. This is different from the regular toe settings you usually make at the steering turnbuckles.
Front sweep angles the front suspension arms backwards, sort of like the wings on a jumbo jet. In theory, its effects are most apparent in the middle of a corner when the car is fully leaned over. more front sweep helps the front end dig in harder for more traction past the apex, but adds rolling resistance and drag.
In stock class you'll want the Cyclone S with 0 degrees front sweep to help it roll through the corners quicker without scrubbing off too much speed.
Mods will run more front sweep, often with a front spool to let the front end dig in hard at corner exit and let motor's abundant power pull the car through the turn quickly.
dinorider is offline   Reply With Quote
Old 02-22-2009, 05:56 PM   #836
Trader Rating: 14 (100%+)
Just got my Cyclone S done. Easy build and seems to be a really great car, especially for $125! Anyway i just built right out of the box, including the shock oil. Anyone know what weight that is? Also what are you guys running for spur and pinion for 17.5. 80/60 sound about right?
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.0 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 02-23-2009, 02:05 PM   #837
M-Tune's Avatar
Default chassis
Chassis. What Chassis should I replace my cyclone s Chassis with.
Hotbodies chassis are around $70
3 racing Chassis is around $40
Old 02-23-2009, 02:25 PM   #838
padailey's Avatar
I've used the 3racing chassis and it seemed fine. The Hot Bodies chassis would be better but you'll need more than just the chassis. The 3racing chassis is designed to be a replacement for the "S" so you get some standoffs, etc so you can attach the top deck. The Hot Bodies chassis I do not believe comes with anything other than the chassis. I could be wrong about that though. I haven't had the car in awhile but that's what I remember.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-25-2009, 08:36 AM   #839
Godbreaker's Avatar
hi guys..need your opinion..my LHS is just selling the cyclone s drift special edition, and i want to use it for carpet racing. Can it be used for carpet race? Coz itz a drift spec model. And do i have to change some parts in the car so i can race it.? much info is needed.
Btw i will be using a 5.5t ezrun brushless motor,with lipo brick pack. And this setup what most racers use in my local track.
Godbreaker is offline   Reply With Quote
Old 02-25-2009, 06:59 PM   #840
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Its the S chassis ok for 13,5 brushless racing on NiMH batts ?
Im thinking on use ezrun esc + speed passion 13,5 or team orion 13,5 motor,
thanks,
Pat
Tabushi is offline   Reply With Quote
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
