Tub Cyclone `S`
#796
One of the guys over here was running either a 4.5 or 3.5 in mod over here while writing a review for it. He basically said it wasnt too bad, although he was a decent driver.
Although i think it was meant to be kit i have a feeling he changed a few parts.
But the flexy chassis can be helpfull in getting a touch more grip.
When you think about it, its really not that different a car as long as you upgrade the parts i mentioned. Personally i dont like aluminium parts cause they bend and you cant tell. Unfortunately, if you are racing mod motors like a 5.5 you should steer clear of the cheaper brands as you will find they are made of softer aluminium.
#797
im running a novak gtb/6.5r setup on my cyclone s with a 108t spur and 33 pinion, i have good speed but the rear is a little loose, can anybody help me out? what settings would i need to change to help get more rear grip. im running sorex premounts 32R compound tires.
thanks
thanks
#799
thanks
thanks
#800
i have a trakpower 4900 using on a cyclone-s with the aluminum purple motor mounts/cyclone-s special edition(got it free from hpi-singapore)..the batts fits in nicely barely leaving abt +/-0.5mm gap in between.
since im new to lipo,
is this advisable to use the trakpower still?
im talking abt the heat dissipation and magnetism effects on the aluminum.
will it affect the lipo in any way?
thank you for ur help
#801
#802
ok..that was very detailed answer.. thank you..
#803
I just picked up a brand new cyclone s. I must say i have built a yokomo bd, tc5, 12r5 and an xray 808 and the build quality with this thing even though its all plastic was easily on par with the above mentioned. I was very impressed.
Anyway i plan to use this car for drifting with a 13.5 brushless. I was wondering what spur pinion combo you guys are running. It seems i will be needing a ridiculously large pinion on this thing to get it to even mesh with the stock spur. Any help would help. thanks
you can pm if you like
#804
#805
cyclone s fr pivot block.
My turnbuckles seem to be binding on the FR Pivot block. I cant seem to find a solution to the problem. If I buy the HB Factory purple aluminum FR Pivot Block, do you think it will have the same problem? Just by looking at some photos it looked like it might be a bit lower profile than the stock plastic one.
#807
Cheers
Adrian
#808
Yeah personally i suspect that was the reason why my chassis has snapped.
It was such a light tap too.
Using the plastic pivot blocks on the front is probably better too as there will be more movement and you are less likely to bend the hinge pins (which will then greatly effect the handling of the car).
With regards to binding it shouldnt be binding if the wheels are on the ground, you are probably checking the suspension while holding the car in the air.
#809
it was the turnbuckles hitting it. I shaved it down and its good.
What size are the shock pistons that come in kit?
#810
Also just a couple of tips that may have been mentioned that I recently found out. If your using the alloy servo saver from the original cyclone or 3 racing make sure you loctite the ball screws in and swap the tie rod that holds the ball cups that connect the servo to the steering for the original cyclone which has a turnbuckle instead it helps with adjustments and also wont allow the tierod to come undone which happened to me in a race recently.
Cheers
Adrian
