Old 03-30-2008, 05:40 AM   #721
MD
MD's Avatar
Trader Rating: 118 (100%+)
From what web site do you guys buy your 3racing parts?
MD is offline   Reply With Quote
Old 03-30-2008, 05:48 AM   #722
Thanks for the advice. I guess I'll use up the ones in the kit then go from there. I have no LHS, so I'll have to buy from somewhere online. Thanks again!!
eric7 is offline   Reply With Quote
Old 03-30-2008, 06:04 AM   #723
RC MARKET's Avatar
rcmarket.com.hk
RC MARKET is offline   Reply With Quote
Old 03-30-2008, 06:09 AM   #724
vazzo's Avatar
Trader Rating: 100 (100%+)
Guys dont hesitate to buy from RC Market, Ive been buying all my Cyclone parts from them and the service is fantastic.
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 03-30-2008, 01:33 PM   #725
RC MARKET's Avatar
Cheers
Adrian
Thanks !
Old 03-30-2008, 05:52 PM   #726
I read on another site about some people having some sort of diff issues with the Cyclone S. Anyone here know anything about that?
Old 03-30-2008, 06:02 PM   #727
MD
MD's Avatar
I know one of Andy Moore's recommendations for the for the regular Cyclone is run a tight rear diff.
Old 03-30-2008, 06:03 PM   #728
vazzo's Avatar
The stock diffs suck, get the 3 racing aluminium diff outdrives in the back, leave the stock pulley in there and upgrade the balls to ceramic ones. If running stock or mod upgrade the front diff to the HB spool v2 or 3 with steel dogbones, if running 540 then purchase the HB front one way. 3 racing does make a spool but I'm not sure what its like.
Cheers
Adrian
Old 03-31-2008, 01:13 AM   #729
mangoman's Avatar
Yes stock diffs are probably not suitable for anything above stock. With regards to running a spool or oneway in the front. if you do this you have to upgrade the centre pulley system.
The plastic centre pulleys will strip on the front belt.
To upgrade the centre pulley system im not sure but i think with the current centre pulley you may be able to still use the plastic spur gear adapter and the plastic centre pulley for the rear belt.
Also i think vazzo means v2 universals. To my knowledge there is no v3 universal or v2 or v3 dogbones.... If you upgrade to universals you also need to upgrade the wheel axles and need the cross joints to assemble the universal.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 04-02-2008, 10:34 AM   #730
I'm awaiting my cyclone S kits arrival. I heard someone mention before that there were some mistakes in the build manual. Anything I need to be aware of?
Old 04-02-2008, 10:39 AM   #731
DustinR's Avatar
Ensure that the pivot blocks are in the right locations whe you screw them into the car. Both front and rear. Even though the are labled (who reads the labels) they look simuler if you put them in the wrong spots the steering will bind.
Put a little bushing lube on the steering bushings. Just a little.
Grandview Hobbies, HobbyWing, J-Concepts, Airtronics, LukeDawg Graphics, TQ Wire
DustinR is offline   Reply With Quote
Old 04-03-2008, 08:26 AM   #732
Thanks. Not to be thick headed but I assume those were things I needed to be aware of and not the mistakes in the manual?
Old 04-03-2008, 11:58 AM   #733
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Can the diffs withstand 27T/17.5 motors with 4600mAh batteries? (box stock kit, no spool, no other mods)
Greg Sharpe is offline   Reply With Quote
Old 04-03-2008, 12:01 PM   #734
DustinR's Avatar
That is correct. I just thought I would give you a heads up as its easy to turn around. You will find no "mistakes" in the manual.
Old 04-04-2008, 07:19 AM   #735
just bought a Cyclone S Drift Special Edition kit, few queries to raise and hope to get some answers:
1. i have all stick type batteries.. can i use them on this kit?
2. if not, is there a thread to show us how to do up the battery pack to a side-by-side pack? What are the equipment needed and wires... or links...any instructional weblink that i can read it up.
3. What is the best pinion size for this kit with spur of 96T?
Pls advise. and Thanks in advance.
viperviper is offline   Reply With Quote
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
