Old 02-26-2008, 11:03 AM   #661
Default Diff issue
I have been running the S for about 6 weeks now. really enjoy the car. my problem is the diff. The first time I built it, the diff lasted 30 packs before feeling gritty. everytime I rebulild the diff, it seems to last shorter and shorter. Now I have to rebuild every 3-5 packs.
Is it possible the balls have worned out? The diff rings etc all are fine. It just gets gritty sooner and sooner.
Any ideas appreciated.
Julienfoo is offline   Reply With Quote
Old 02-26-2008, 11:06 AM   #662
Trader Rating: 38 (100%+)
Replace the diff balls with ceramic and get the JAAD racing diff covers and you wont need to rebuild the diff for a very long time.
or8ital is offline   Reply With Quote
Old 02-26-2008, 11:06 AM   #663
Old 02-26-2008, 01:18 PM   #664
MD
MD's Avatar
Trader Rating: 112 (100%+)
I know Andy Moore recommends running the rear diff tight to very tight on the regular Cyclone.
MD is offline   Reply With Quote
Old 02-26-2008, 05:52 PM   #665
Are we saying that worn diff balls can cause grittyness? I was suspecting the trust bearings. I will pick up another pack of balls and have a got. Ceramics are out of my budget right now.
Cheers
Old 02-27-2008, 04:57 AM   #666
rccobra705's Avatar
Please, tell me where to buy these JAAD diff plate in the US or Hong Kong/Japan.
rccobra705 is offline   Reply With Quote
Old 02-27-2008, 05:08 AM   #667
here you go:
http://www.precisionrc.com/nv/car/pr...e=jaad+cyclone
Old 02-27-2008, 12:39 PM   #668
rccobra705's Avatar
or8ital, Thanks you
Old 02-27-2008, 08:59 PM   #669
.:hyperdrive:.'s Avatar
Or you could make your own diff covers from self-adhesive vinyl or contact paper, cut using a circle cutter. I was lucky enough to find a shiny purple one to match all the other purple bling . Don't forget to smear a bit of diff lube on the back of the cover where it meets the diff halves.
.:hyperdrive:. is offline   Reply With Quote
Old 02-29-2008, 12:06 AM   #670
bullfrog_racer's Avatar
Default 3Racing Spur + one way
Hi all, I have just installed the 3Racing center oneway, spur holder etc, CY-17/18/30 (http://www.3racing.com.hk/manuals/cy17.jpg) and used the 18 tooth pulley to lower my internal ratio, the problem I have is the belt is sooooo tight!, I have tried reversing the Diff bearing holders but it didnt help much if at all, any ideas in how to loosen it so it can move freely? Thanks for any help in advance!
Team Associated 12R 5.1 5.5T :: Team Magic G4S - OS 12TZ :: Mugen MBX5T - OS VB V Spec
bullfrog_racer is offline   Reply With Quote
Old 02-29-2008, 05:58 AM   #671
When you switch to the 18T pulley, you'll need to use the longer drive belts, ie the 170T (#66493) front, and 63T (#66494) rear belt. If you don't want to change belts, use the 17T pulley instead. Can I ask what FDR you're aiming for?
Old 03-01-2008, 01:44 AM   #672
I wanted to lower the internal ratio due to the fact I am too slow off the line and out of sharp corners, my acceleration cant match a few of the other cars and I am loosing a few vital placings at the start. So was aiming for 2.16 using the 18T pulleys, thanks for the advice with the belts, thier is always heaps too learn!.
Old 03-01-2008, 04:41 AM   #673
If your trying to increase your acceleration, you need to increase your FDR (Final Drive Ratio = Spur/Pinion x internal ratio). So by decreasing your internal ratio, you're decreasing acceleration even further. Instead of playing around with the internal ratio, start with changing your gear ratio. Smaller pinion, or larger spur, or a combination of both will give you faster acceleration, but your top speed will decrease. Probably easiest to go get a pinion that is 1 or 2T smaller, if your motor mount allows it.
Old 03-01-2008, 09:45 AM   #674
mangoman's Avatar
Keep in mind that if you are running a budget esc compared to those racers who are beating you....
Then it is likely that the esc could be playing a large part in their pickup off the line and out of corners. Of course a good motor helps too (if it is brushed)
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 03-02-2008, 12:04 AM   #675
I am pretty much a newbie so all comments are greatly appriciated, can someone explain how a better ESC can help I am using a budget Futaba 230 ESC at the moment? I run in a class which uses the standard silver can motor, once I am getting consistant top 3 in the class I am going to jump up to brushless which we should be running next season. Cheers
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
