Old 09-12-2007, 11:29 AM   #631
Deves's Avatar
I did notice they leak a little around the top but a small o ring type gasket will fix that.
Deves is offline   Reply With Quote
Old 10-08-2007, 12:13 AM   #632
bullfrog_racer's Avatar
Default Front 3Racing Spool
Hey guys, can you help please. I run a silvercan motor and am considering trying a front 3racing spool.
http://www.3racing.com.hk/x_descript...ducts_key=8760
I was wondering what else I need as I cannot see how the front belt attaches or do you just use the exsisting from drive gear?
Thanks in advance
bullfrog_racer is offline   Reply With Quote
Old 10-08-2007, 06:45 AM   #633
vazzo's Avatar
Trader Rating: 100 (100%+)
use the existing belt, just make sure you purchase the v2 steel hb drive shaft and the hb axles.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 10-09-2007, 12:54 AM   #634
Smile
Is it possible to use the 3Racing universals? or am I best to stick with the HB products? I cant see myself running anything other than a silvercan. Thanks
Old 10-09-2007, 06:49 PM   #635
vazzo's Avatar
3Racing uni's should be fine for silver can racing bullfrog, as soon as you go into stock make sure you buy the HB spool, one way pulley, drive shaft and axles as they are much stronger. I thought you'd be better off running a front one way in 540 as you dont generally use brakes so it would certainly give you more speed.
cheers
adrian
Old 10-10-2007, 12:30 AM   #636
Smile
cheers
adrian
More speed is what I am after, would a front oneway be faster than a spool using a silvercan? you are right I can drive the track with out using the brakes, I just throttle off on the corners and average 7th in the A final, I run a 51mm rollout as its really a nitro track with long back straight but has alot of twisties on the front. Do 3Racing do a front oneway? Thanks in advance.
Old 10-18-2007, 05:55 AM   #637
mangoman's Avatar
Spool scrubs off speed through corners, which is critical to 540 as the motor has no torque.
Even in stock in most cases you would be better off using a one-way though. The spool is easier to drive but if you are good enough then a one-way should be faster in stock.
Once you move up from stock the spool really starts to become most effective.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-18-2007, 11:19 PM   #638
About the Oneway, I see you can use a HB front oneway or 3Racing Center oneway, am pretty confused about what the difference is?
Great too see lots of helpful advise!
Cheers Guys!!
Team Associated 12R 5.1 5.5T :: Team Magic G4S - OS 12TZ :: Mugen MBX5T - OS VB V Spec
Old 10-22-2007, 03:48 PM   #639
mangoman's Avatar
There is a HB Centre One-way as well.
With the one-way you still have options which you can run at the front of the car. Ive never used a centre one-way and i've been told they are a pain as they get gritty easily and need constant cleaning.
When they get gritty the car the drive then becomes inconsistent.
Apparently using a centre one-way and a front one-way together is the most efficient drive but **SHRUG**?!?!?!?!?!?
www.smaracing.org
Old 10-22-2007, 08:51 PM   #640
MD
MD's Avatar
Trader Rating: 118 (100%+)
Does HPI or anyone else make aluminum "C" hubs for the cyclone "S?"
MD is offline   Reply With Quote
Old 10-22-2007, 11:02 PM   #641
mangoman's Avatar
HPI/HB dont but there are a few manufacturers around.
3 racing make them and i think Jet also make them (Pro 4 C Hubs are the same).
In my opinion though you are better sticking with the carbon graphite C hubs.
Note that the Cyclone S C-Hubs are different and they are ridiculously brittle
Aluminium C Hubs tend to bend and then this tweaks the car without you being able to work out what is wrong.
www.smaracing.org
Old 11-19-2007, 04:29 AM   #642
vazzo's Avatar
Can someone plz post up there setup sheet for stock ashphalt?
Cheers
Adrian
Old 11-20-2007, 08:00 PM   #643
mangoman's Avatar
Hmm i havent seen any setup sheets for the Cyclone S floating around.
But you probably want to set it up pretty similar to how all the other people setup the full cyclones.
I changed over the pivot blocks on mine but am suspect as to whether this caused my chasis to snap. Otherwise i would probably run a 2.5 degree block on the rear (assuming that is brushed stock on not brushless stock).
You need to raise the pivot block to as the plastic ones seem to have spacers built into them. On my S with a CF main chassis i raised the pivot blocks 1.5mm to match the plastic FR RF blocks.
Probably use the top mounting holes on the shock towers.
www.smaracing.org
Old 11-25-2007, 09:19 PM   #644
hi,
newbie here, 1 question pls, what is the best gear setup (48p) with 23t stock motor for cyclone S, (using rubber tyre)
thanks
limau is offline   Reply With Quote
Old 11-26-2007, 02:07 AM   #645
mangoman's Avatar
Originally Posted by limau View Post
hi,
thanks
I have no idea, you need to ask at your track the best rollout or final drive ratio. Gearing is dependant on many factors such as track size surface, type of motor and driving style (to name a few). For instance two different trinity 27T stock motors have a gearing difference of about 3 pinion teeth to get maximal peformance
Once you find out the rollout or final drive ratio you want to use i can help you out with the pinions and spurs that you may want to get.
Remember to tell people what motor you are using when you ask at the track, if no one will tell you i would go to a different track as it means they are not very friendly people and wont be very fun to race with
www.smaracing.org
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
