Old 07-17-2007, 06:35 PM   #556
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Does anybody have a good setup for rubber tire on asphalt with a 19t motor?
CarlosG. is offline   Reply With Quote
Old 07-18-2007, 05:34 AM   #557
mangoman's Avatar
With the clicking you should really try and determine the source of the noise incase it is something potentially serious.
Take of one of the belts and isolate if its coming from the front or rear.
Then take out the dogbones. The clicking maybe be coming from the join where the dogbone sits in the cups of the axle stubs.
The dif pulley will move on the diff. Take into account they are held in place on the diff balls and not by being sandwiched between the diff cups. If they were tight on the diff balls well then the diff balls probably wouldnt turn and if the diff cups were tightened up tight onto the diff pulley the diff cups wont turn independently....
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-18-2007, 05:47 AM   #558
mangoman's Avatar
Carlos, I didnt really play with my cyclone S much in stock settings. The cyclone S comes with a lot of features built into it which you would normally use for a good setup.
I would personally look at upgrading the car and going for universals and a spool. The spool will punish the drivetrain a bit so make sure you get the HD Steel dogbones and NOT aluminium universals if you upgrading them.
www.smaracing.org
Old 07-18-2007, 06:18 AM   #559
RC MARKET's Avatar
Originally Posted by mangoman View Post
Get the carbon graphite c hubs. In hmm i think its 3 years of racing (pro 4 and cyclone) i think ive only ever broken one.
The Part No. is 73518
Yes Pro 4 to now !
RC MARKET is offline   Reply With Quote
Old 07-18-2007, 08:23 AM   #560
padailey's Avatar
Originally Posted by MonkeyFist View Post
Also are the diff pullies supposed to have side to side play in them?
Yes
padailey is offline   Reply With Quote
Old 07-18-2007, 09:12 PM   #561
OK I found where it is rubbing. If you have acess to the manual it on page 8 top pic part number75143b. In the Cyclone S kit its the purple servo saver collar at the base of the steering column. I know it rubbing there because the anodize is actually rubbed off. Now the question is how to fix it. Since the rub is not constant that leads me to believe that the belt is not tracking straight. Moving side to side hitting the collar. Any hints on how to fix it?
MonkeyFist is offline   Reply With Quote
Old 07-19-2007, 11:44 PM   #562
mangoman's Avatar
You sure the servo saver is assembled properly?
The belt should be near it
Is the shim on the center shaft in the right place?
www.smaracing.org
Old 07-20-2007, 02:38 PM   #563
I checked the assembly on the servo saver, that checks out ok. By center shaft you the the lay shaft? I'll check that out and see if I got that wrong. I noticed that my diffs have alot of side to side play between the bulkheads. I looked in the manual for the Hara edition of the cyclone they have washers that go between the out drives and the diff bearings. I'm wondering if I used washers on one side to keep the diff away from the servo saver collar if that would help.
Old 07-20-2007, 07:46 PM   #564
mangoman's Avatar
Sorry yeah, the layshaft is what i meant.
With the shims around the diff, they are quite thin shims like .1 and .2 mm i think off the top of my head, so the play shouldnt really be that excessive.
If you can take any decent pictures of your car perhaps that might help me see if there is anything unusual. So you checked that the collar to the servo saver hasnt come undone?
www.smaracing.org
Old 07-20-2007, 11:10 PM   #565
My kit had no shims for the diff in it at all. The collar on the servo saver is assembled just like the manual.
Old 07-21-2007, 07:08 AM   #566
mangoman's Avatar
Yes but are you sure it hasnt come loose?
www.smaracing.org
Old 07-21-2007, 11:22 AM   #567
Nope the collar is snug. If I can find the right thikness shim to put between the out drive cup and the diff bearing it looks like it should solve the problem. If it wokrs I'll try and snap a few pics. By the way thank you for all your help mangoman.
Old 07-21-2007, 07:30 PM   #568
Trader Rating: 198 (100%+)
I ran the S today in a very close race. We run on a large medium outdoor track. I usually run a Cyclone but I sold it. I just have the S left. With the only items changed from stock such as , rear diff is alloy, 3racing layshaft pully, and narrow wheel hex's. The car is stock. It ran great. I run in a 19t/10.5 class. With some very fast local guys. The car was very impressive. It seemed to run better than the other cyclone I had. I finished 2nd with the top 4 less than 2 seconds apart. It was an awsome main for us.
Here is my set up.
Front
Camber link lower hole
shock, 2nd hole out top, lower outer hole
silver spring
45wt Losi oil stock piston
4 degree caster
diff very tight.
stock arm mounts
Rear
shock, 4th hole out on tower, middle on arm
silver spring
45wt oil Losi
hub, .75 shim forward then hub then 2mm shim
stock arm mounts
Atlas red can with F-brush stock silver springs ran at a 6.25 FDR
RP30 tires
DNA 2 body, wing centered
Car weight of 1525g
Orion 4800 lipo
LRP quantum sport esc
Airtronics 94257 servo
Airtronics rec.
This setup rocks! I may go longer on the wheel base next time. Car had good steering low speed and high speed.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 07-22-2007, 04:02 AM   #569
mangoman's Avatar
No Worries MonkeyFist, i cant really think of anything else that could be wrong
www.smaracing.org
Old 07-22-2007, 10:20 AM   #570
You tried Mangman, thanks. I couldn't find the right size shims yesterday, so I riggrd up a temp one that seemed to help, I need better shims to make sure.
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
