Old 03-18-2007, 12:59 AM   #481
nino_pohan's Avatar
If i buy standart cyclone S, i get plastic threaded shock?
nino_pohan is offline   Reply With Quote
Old 03-18-2007, 01:27 AM   #482
mangoman's Avatar
Yes it comes with plastic shocks.
Ive heard they are not too bad except the hole at the bottom sometimes binds on the piston shaft so you should check the piston moves smoothly before filling the shock with oil.
I never built mine as i stole a set of my pro 4
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 03-18-2007, 01:27 AM   #483
bullfrog_racer's Avatar
Thats right the Cyclone S comes standard with plastic shocks, they seem to work fine though. You can of course upgrade them with aftermarket alloy ones.
Team Associated 12R 5.1 5.5T :: Team Magic G4S - OS 12TZ :: Mugen MBX5T - OS VB V Spec
bullfrog_racer is offline   Reply With Quote
Old 03-18-2007, 03:29 PM   #484
Hi Guys has anyone got a good setup for carpet with foams ?
Y.Bear is offline   Reply With Quote
Old 03-19-2007, 02:04 PM   #485
RC MARKET's Avatar
yes ,i'm think change alum. bester
RC MARKET is offline   Reply With Quote
Old 03-19-2007, 10:45 PM   #486
nino_pohan's Avatar
I know is plastic but is the shock threaded (adjustable)???
Old 03-20-2007, 12:50 AM   #487
turtle's Avatar
Yes the shocks are threaded plastic.
turtle is offline   Reply With Quote
Old 03-20-2007, 11:31 AM   #488
rccobra705's Avatar
Default Cyclone S
Hi, I'm planning to buy one of these Cyclone S cars. My question to you is, which pinion or pinions, do I need if I only run stock spur (96 T) with stock motor Trinity P2K pro.
rccobra705 is offline   Reply With Quote
Old 03-20-2007, 12:09 PM   #489
padailey's Avatar
I think with a 96T (assuming 64P) you will need a 34 tooth or larger pinion to get them to mesh properly (34 barely reaches the spur). You'll have to see if that works for the gearing you want. Otherwise you will need a different spur. I think you can go up to 104 teeth without modification to the chassis.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 03-20-2007, 03:03 PM   #490
rccobra705's Avatar
Thanks padailey,
To get the mesh fit properly what do I need to due.
Old 03-20-2007, 05:25 PM   #491
turtle's Avatar
I use a 48P 69T spur (as suggested my mangoman) and the use 39-41t pinions, but I am only running 540. I put a 27turn stock motor in the other week with a 34T pinion and it seemed to mesh ok, but you may have to file a bit of the plastic away if you go much smaller as the motor will hit.
Old 03-20-2007, 09:11 PM   #492
padailey's Avatar
Well I don't run a 27T motor (13.5 brushless) but from reading here and on the cyclone thread I think a lot of guys are running 100 or 104 tooth spurs (64P), or run a pinion 34 or larger with the 96T. Either way seems to take care of the problem. The problem is that the motor won't move very far so meshing can be a little bit of a pain for some. When I was running without a sintered rotor I was running 37 pinion and 100 or 94 spur.
Tamiya TRF416X
Old 03-20-2007, 11:58 PM   #493
nino_pohan's Avatar
Thanks.. all version of cyclone S include Cyclone S drift?
Old 03-21-2007, 01:10 AM   #494
mangoman's Avatar
Is that a question nino_pohan?
BTW if you get a Cyclone S get a set of the Carbon Graphite C Hubs (Part No. HPI73518).
The ones which come with the cyclone s are made of some brittle plastic.
www.smaracing.org
Old 03-21-2007, 01:14 AM   #495
mangoman's Avatar
Oh theres a cyclone s drift kit now, i wonder what the difference is?
Just different tyres and decals for the car?
www.smaracing.org
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
