Old 11-14-2006, 07:44 AM   #316
padailey's Avatar
I havent run the car yet but found problems with tolerances in two areas. When screwing down the bulkhead covers it seems to put so much pressure on the standard plastic diff bearing holders that it causes binding in the drive train. (dont know what to do with this yet....)
Hmmm wonder if that might be my problem also. Got my 3 racing chassis yesterday and everything went together well till I got the front upper bulkhead and shock towers on. Before that everything was loose and free.. felt great. I wonder if a tiny little shim between the bulkheads would cure it. Guess I should experiment a little and see if that is actually the problem.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 11-14-2006, 07:45 AM   #317
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Anybody that is looking to update their Cyclone "S" with a graphite chassis, I have a complete Kit that I no longer need, its a brand new chassis,top deck and shock towers!! pm me if interested.
I bought a hara kit and built it for carpet (BMI chassis)
Old 11-14-2006, 08:09 AM   #318
Can you take a cyclone S, slap a BMI chassis on it and use it for carpet? Or are some parts on the S not as high quality as a regular cyclone?
JoelV is offline   Reply With Quote
Old 11-14-2006, 08:09 AM   #319
Super Moderator
Marcos.J's Avatar
you can
Old 11-14-2006, 08:35 AM   #320
padailey's Avatar
Marcos is right about the chassis itself... however with the whole BMI kit you will need the cyclone upper bulkheads to use the BMI shock towers. As far as not as high quality .... well the "S" is plastic so and the scaled down version so yes some of the parts are not as high quality. The parts causing me the most grief are the dogbones, plastic diffs, and chassis. I've replaced the chassis and parts coming for the others. Another common problem folks have been having is stripping the center pulleys.. personally I've had no issues with that. Even with those issues I really like how the car drives, its just those parts are causing me to break a little more than I should be.
Tamiya TRF416X
Old 11-14-2006, 07:39 PM   #321
mangoman's Avatar
Originally Posted by pearl
try loosening your belts so your drivetrain parts, specially the center pulley, won't be stressed much. your motor must have serious power
Okkie thanks pearl will try. Unfortunately the motor doesnt have that much power Just been using a CO27 and had a couple of runs with a Komodo
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-14-2006, 08:01 PM   #322
mangoman's Avatar
Yeah i was thinking about shimming it too, but when i placed the bulk head covers over the bulkeads with the diff bearing holders i saw there was quite a large gap. I figured that shimming the part would still create a fair amount of flex to occur and esepcially as they hold the shock towers i decided to ditch the bulkheads and just use the bulk head covers with the graphite shock towers till i get some feedback on the items.
I posted a query on the 3racing.com.hk forum about this but noone has replied yet
www.smaracing.org
Old 11-16-2006, 03:14 PM   #323
yyhayyim's Avatar
Trader Rating: 26 (100%+)
What should I do? I can get the Cyclone "S", but need it to be able to handle Novak 4.5R motor. Dont know if the stock plastic outdrives can handle it. Will propably need front aluminum outdrives or steel ones, and delrin rears. Will need new CVD's. Will also get CF shock towers, top deck and chassis. Any other suggestions?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-16-2006, 03:26 PM   #324
bxpitbull's Avatar
It will definately need metal outdrives. The dogbones will hold out, but be prepared to work those diffs. To reduce flex, upgrade to main and upper chassis woven from Horizon Hobby. Stiffen the springs and you are almost there. Most places dont have the metal outdrives in stock. Titanium racing does, but it aint cheap. $71 dollars for the car, shipped. BUT, they help. Also, get the Cyclone blades. Ebay has the shock towers for like $17 apiece, so get it while they last.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 11-16-2006, 03:39 PM   #325
padailey's Avatar
yyhayyim - Might want to upgrade the center pulley system also.
Tamiya TRF416X
Old 11-16-2006, 06:11 PM   #326
mangoman's Avatar
yyhayyim, If you know you want to upgrade that much stuff you should do some calculations to see how the pricing compares relative to buying the full kit. I've sunk a bit of money into my cyclone S at the moment, although it was partially done with the intent of seing how it would upgrade.
www.smaracing.org
Old 11-16-2006, 08:36 PM   #327
kwellst's Avatar
Send a message via AIM to kwellst
where can you get the blades at??
Associated RC18B
kwellst is offline   Reply With Quote
Old 11-16-2006, 08:59 PM   #328
who has the cheapest price on these?
TZona is offline   Reply With Quote
Old 11-17-2006, 07:27 AM   #329
bxpitbull's Avatar
Marginally, upgrading in increments comes out to be slightly more expensive in the long run but, that being said, there are hop-ups that one doesnt need to purchase for the car to be competitive.
Old 11-17-2006, 08:01 AM   #330
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I would try speedtech or if all else fails contacts Champs in Japan.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
HotBodies Cyclone WCE MooreSpeed Andy Moore Cyclone SammyZ R/C Items: For Sale/Trade 20 07-08-2010 11:17 AM
Taking Time Off Sale: Cyclone,VTA Cyclone,M03 Mini Coopers,F201,12L,T3, LOTS of MISC bmr R/C Items: For Sale/Trade 82 03-09-2009 10:13 AM
2 x HB Cyclone WCE, cyclone parts & other electric items NickM Australia For Sale/Trade 8 04-19-2008 06:28 PM
Cyclone/Cyclone S front and rear belts vazzo Australia For Sale/Trade 0 02-28-2008 06:26 PM
FS: 3Racing Sway bar sets for Cyclone/Cyclone S vazzo Australia For Sale/Trade 1 02-07-2008 02:54 AM
