Old 04-25-2006, 09:11 AM   #1
Iceracer's Avatar
Default Seperating ball joints
What's the proper way to remove a plastic socket end of a tie rod from a ball joint in order to minimize wear and tear. Does it wear out the socket every time you pry one off?
Iceracer is offline   Reply With Quote
Old 04-25-2006, 09:34 AM   #2
JayL's Avatar
3racing has a cool tool
precisionrc has them
JayL is offline   Reply With Quote
Old 04-25-2006, 11:25 AM   #3
timmay70's Avatar
I use a pair of locking needle nose pliers, however, I don't let them lock on the rod end... Grip the rod end where the turnbuckle goes in so that you are gripping the plastic over the metal.... this way it won't crush, and it allows you to add more pressure if you find the pliers slipping. Next, rotate the pliers the same as you would as if you are making a turnbuckle adjustment. The sucker should pop right off.
I replace my rod ends (ball cups) whenever they are showing excessive wear, or when one pops off. I usually replace all of them at once, as they are all probably worn to some extent. It also keeps the chassis nice and tight.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 04-25-2006, 08:04 PM   #4
Yeti35's Avatar
I personally just use a curved pick, for I just happened to have one in my box. I just get the pick under the ball cup and pry up and it pops off.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Breaking Universal Joints racer12306 Monster Trucks 3 07-07-2008 08:37 AM
AD1 CVD joints/uni's gatermaxx Electric Off-Road 4 05-24-2007 01:34 PM
new motor? better ball joints? yo_man_will Rookie Zone 3 08-09-2005 09:04 PM
Oiling all the joints?? vti-chris Electric Off-Road 3 02-11-2005 04:04 AM
Lubing Joints jforkner Electric Off-Road 3 01-05-2003 01:03 PM
SEO by vBSEO 3.5.0
