Old 04-25-2006, 07:25 AM   #1
Default problem car jolting
hi im a newbie to this bought myself a tamiya TL-01 kit also bought tamiya TEU-101BK ESC set the speed controller the way it tells me to but when i put full throttle or over half way it jolts forward or backwards, im not too sure if its the motor or wether its the ESC help would be greatly appreciated
hemsy is offline   Reply With Quote
Old 04-25-2006, 07:45 AM   #2
sosidge's Avatar
Is it the standard motor or is it an upgraded one?
Is the battery pack fully charged?
Sounds like the problem is essentially the suppply of power to the motor.
Either the batteries can't supply as much as the motor is demanding (faulty pack/low charge), or the motor is trying to demand too much (overpowered motor/mechanical fault causing excess strain).
Also possible are a faulty speed controller, bad contacts, or a badly suppressed motor (solder on capacitors, often pre-fitted on modern motors).
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 08:07 PM
Problem with ESC strongville Electric On-Road 2 11-29-2005 06:00 AM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 06:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 04:08 AM
SEO by vBSEO 3.5.0
