Old 12-30-2002, 05:10 PM   #16
I have got over a years racing on a set of 138g's. They will last ages. Take Off CS27's seem to give a little bit more steering and also last a long time(have not raced them more than about 5 meets so cannot say exactly how long)
ixlr8nz is offline   Reply With Quote
Old 12-30-2002, 05:37 PM   #17
Canuck's Avatar
Trader Rating: 25 (100%+)
Thank's . I kind of figured that the 138G were good after receiving so much replies and advice. Once and a while someone will throw you for a spin and give you bad advice !
Will go with the 138G.
Canuck is offline   Reply With Quote
Old 12-30-2002, 05:57 PM   #18
popsracer's Avatar
Default Tire life
Two things have a big impact on tire life, compound and insert. You should be fine with the HPI Red inserts, especially on an Electric Car.
It is the 139's that wear very quickly, the rubber is much thinner.
The Yokomo's work best on older asphalt that the slurry has been worn/washed away and the gravel is more exposed. With Freshly layed or slurry sealed asphalt, Sorex 36R's will have the advantage. This is what I have found after much experimentation with tires over the years.
popsracer is offline   Reply With Quote
Old 12-30-2002, 09:11 PM   #19
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
If the asphalt is clean and has decent traction you will need to run the Hpi greens if you are dead set on running HPI inserts. This applies to Yok, Sorex and Pit tires. If you decide to run the Take Off CS tires, just run the premounts- they are by far the best value and to be honest they are faster than the Yoks. I see numerous people have tried to tell you the CS tires are better but it looks like you still intend to run the Yoks, so get the HPI greens. The HPI reds will let the inside lip of the tire roll over and chew up the edge of the tire if you have your car setup well with decent traction.
BigDogRacing is offline   Reply With Quote
FS: PIT SHIMIZU TIRES 24mm JoeyE R/C Items: For Sale/Trade 0 12-30-2007 07:58 PM
Could i put 24mm rims on 25mm tires ? thahookup Rookie Zone 1 04-28-2006 06:28 AM
24mm Foam Tires BringItOn Australia For Sale/Trade 0 03-22-2006 11:29 PM
Where to get HPI 27r 24mm tires DustinR Electric On-Road 6 07-18-2005 11:36 AM
Wanted: HPI 24mm 27R Tires NIB DustinR R/C Items: Wanted to Buy 0 07-10-2005 06:36 PM
SEO by vBSEO 3.5.0
