Old 04-26-2006, 07:49 AM   #16
nagatahawk's Avatar
I have a tbo2, with almost all the options, one way , allum. shocks, sway bar etc., that I raced at the TCS nats last year. the TAO5's were new and fast right out of the box. They were about .5 seconds faster a lap than my car.
I will probably buy one sometime this year. although I will run the tbo2 at the tcs qualifier.
nagatahawk is offline   Reply With Quote
Old 04-26-2006, 08:37 AM   #17
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Yup, the TA05 for sure.. maintenance-wise, you don't have to take off the sway bar holder (and the bumper if you want the front) before opening up diff cases..
Want to change a spur? Pop 5 screws to get to the gear, unlike popping the rear diff box/sway holder and sliding out the shaft while balancing shims and a crown gear on the end. Plus, as noted, you have the choice of any spur/pinion you want.
Hit a wall hard? Belts can absorb the stretch, no biggie.. but those bevel crown gears I've gone through tons, especially with the one-way.. I've abused my TA05 in tons of races, one-way or not, but I've only bent a suspension shaft.. can't say that for my TB02..
Finally, the 05 has a reinforced diff option to its stock diffs (just like the discontinued Evo III diffs), at a decent price.. the 02 now has the stock ones (went through a whack of those too) and the ultra-spensive delrin ones.. only if they brought back the Evo III part, that'd be smart..
The TA05 will continue to be focused on by Tamiya to TRF form, whereas the TB-02's already had its TRF equivalent.. the Evo III. In full working order, the TB-02 was responsive, smooth with stock motors, and a pleasure to drive, but the 05 is simply a better car, and easier to work on and to keep in working order.
Now, question is, will the TB-03 be a tub version of the Evo V?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
wtb: f103gt f201 ta05 tb02 J-PaP Australia Wanted to Buy 0 01-05-2008 08:26 PM
tamiya tt01 ta04 ta05 tb02 willabong Australia Wanted to Buy 2 08-27-2006 08:37 PM
FS: Tamiya TA05 (hopped) RTR & TB02 (hopped) Roller crzydrifter R/C Items: For Sale/Trade 9 07-10-2006 11:23 AM
TB02 vs. TA05 Seatbelt Electric On-Road 13 09-01-2005 01:43 AM
Tamiya TA05 and TB02. N15M0 Singapore R/C Racers 23 08-05-2005 09:23 AM
SEO by vBSEO 3.5.0
