Old 04-18-2006, 03:28 PM   #1
aN4rK1's Avatar
Default Novak SS5800 Brushless System Questions
I decided to give the ball bearing in my SS5800 motor a good clean today. I took apart the motor, cleaned all the gunk, and sprayed a little WD40. I cleaned the excess WD40 and put the motor back together. Now i decided to give the arm a little spin by hand to see if I put it back together right. It spun and then spun an extra 2 or 3 full turns. Now i dont remember it doing that before I cleaned it. Is this happening because I cleaned it or because i got something wrong?
I tired the motor out with a battery pack and it seemed ok.
aN4rK1 is offline   Reply With Quote
Old 04-18-2006, 11:41 PM   #2
syndr0me's Avatar
Trader Rating: 31 (100%+)
There's a section in the manual about motor maintenance. Basically, you don't want to use anything but compressed air to clean the motors, and then a light oil in the bearings. Not sure if you've damaged yours, I guess only time will tell.
Here's a link to the PDF that came with your motor. Check out the section that explains "motor maintenance."
syndr0me is offline   Reply With Quote
Old 04-19-2006, 07:42 AM   #3
nagatahawk's Avatar
brushless motors don't have permanent magnets nor brushes to put drag on a free un electrically excited motor. Yours sound normal. I would use a modified oil to lube the bearings. WD40 is a penetrant not a lubricant.
nagatahawk is offline   Reply With Quote
Old 04-19-2006, 08:56 AM   #4
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
Like mentioned above Brushless motors dont have a large amount of natural cogging because of the design. Also witht there being no brushes alot of the drag is gone.
When the motor is fully asembeled it should spin fairly freely
It sounds like there is NOTHING wrong with the motor so run it and it should be fine.
If you ahve any more questions please visit the website
or shoot me a line
Andrew Swanson is offline   Reply With Quote
Old 04-19-2006, 09:06 AM   #5
aN4rK1's Avatar
Thanks a lot guys. Andrew I will be email you soon. Thanks again.
Novak SS5800 Brushless System FS hot4teach R/C Items: For Sale/Trade 7 02-02-2008 11:23 PM
Novak SS5800 brushless system chrism86 Australia For Sale/Trade 1 02-22-2007 06:15 AM
Novak SS5800 Brushless System jake86 R/C Items: For Sale/Trade 5 01-16-2006 09:40 PM
Novak SS5800 Brushless System domo Australia For Sale/Trade 2 01-02-2006 11:21 PM
Novak SS5800 Brushless System supralative R/C Items: For Sale/Trade 2 05-31-2005 05:20 AM
SEO by vBSEO 3.5.0
