Like Tree1Likes
Old 05-31-2008, 01:34 PM   #1471
factory racer's Avatar
i am sellin a brand new evo 5 in the for sale forum somewhere......i no its not the place to sell but just checking, its a built evo 5 but brand new never had any electronics or anything ever mounted in it......askin 250 for it and everything that came in the box.........thanks
Mike
factory racer is offline   Reply With Quote
Old 06-01-2008, 04:15 AM   #1472
Is there anything we can do to seal the gear cover better? I keep getting a lot of fine sand...and they eat up the gears pretty quick. I try put some grease around the edges of the gear cover to catch them but some still finds there way to the gears...
chumanji is offline   Reply With Quote
Old 06-01-2008, 11:09 AM   #1473
Blueman Austria's Avatar
Hm.. I dont have issues but i race only on permanent tracks.
Do you grease the gears? If yes, then run them dry. Then the sand will not stick on them and a second big advantage is the reduce of friction in the drivetrain and it spinns much better.
Another thing. Try it one time without the gearcovers ??? Maybee it works.
To seal it better i have also no better idea. I would use the AW-Grease because this is very sticky.
Greetings Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 06-15-2008, 02:22 PM   #1474
Hy there !
today i attached the electronics in my 415MSXX MRE07, and also re-wired my Evo5.
Here is the result :
And this is the Family picture :
Are they not cute?
By the way! When will the Evo5 MS arrive in stores?
Have anybody of you preorderd one?
Greetings Blueman
Old 06-15-2008, 04:07 PM   #1475
Send a message via ICQ to rcnewb2004
Hey Blueman, those are awesome pictures. You are making me envious... I wish my evo5 could look as good!
One question though... is it a good idea to leave the wires over the fan like that on the evo5?
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 06-15-2008, 10:34 PM   #1476
That doesnt mater. When you look from the side there is enugh gap between.
Old 06-16-2008, 09:15 AM   #1477
Mooshu Beef's Avatar
Hey guys, this is my first time in the Evo 5 forum.
Ever since getting the Mamba system, I've shattered the drivetrain of both a TT-01 and Pro2 (RS4 Rally). I've come here because I am looking to purchase a Evo 4, which seems similar to the Evo 5.
My question is, how does the drivetrain hold up? Are there parts interchangeable between them?
Yes, I have done searches on both the forum and on google, so I figure that you guys might be able to help.
I am not a racer, but drifter. I am willing to see if I can get this chassis to go sideways nicely, seeing as it seems to have a nice drivetrain and plenty of parts.
Thanks ahead of time for any responses!
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 06-16-2008, 10:17 AM   #1478
there is a separate thread for evo iv's. gears are not interchangeable between the two, but suspension parts are compatible. not much else can be used. Gears are made from graphite material, so they will be much more durable than tt01. evo's come with oneway stock. if you dont like using one ways, it might be a pain in the neck sourcing parts for a second diff or, finding the elusive tamiya spool.
slomo is offline   Reply With Quote
Old 06-16-2008, 10:54 PM   #1479
As slomo said before, the gears and drivetrain parts are not interchangeable.
I have an Evo4MS full hopedup, but never tried drifting before. The drivetrain should holdup very well i think, because the forces on it are not very strong when you are drifting. There is (was) also a spool available for this car, wich is a good thing for you drifters (i think).
Currently my Evo4 has a retired at the moment.
The problem is to much cars, and so little Time...
Greetings Blueman
Old 06-19-2008, 12:59 PM   #1480
Default Evo 5 MS in Stock!
For those who are interrested.
The Evo5 MS Kit is in Stock at stellamodels.net
Anybody plan to get one, or has already ordered?
I am very sad about that they deliver the kit in the new TRF Kit Family Box.
The old Evo Style Kitbox was so stylish....
Greets Blueman
Old 06-19-2008, 02:55 PM   #1481
I will occasionally throw on rubber tires too though, which is why my Pro 2 just shredded one of the insides of the pulleys turnign the rear belt, so it's FWD...
I was basically just asking how smooth the drivetrain is. I am assuming there is a bevel gear in the back to turn the diff?
Old 06-20-2008, 01:29 AM   #1482
Yes of course there is a bevel gear in the back (and front). The drivetrain is shaft typical very smooth.
When you wash out the bearings with brake cleaner, and then yust oil it (with WD40, ore other thin oils), then it will spinn very free.
Greets, Blueman
Old 06-20-2008, 02:26 AM   #1483
Default Evo 5 MS Info Page
Found this on Tamiya japan.
http://www.tamiya.com/japan/products...5_ms/index.htm
There are some more detailed pics of the rear of the car.
If the holes on the lower deck for the motor mount are the same as of the normal 5ér, then i will get a MS motormuont and the blue Alu Spur gear frame.
Ill take my old upper deck, Cut of the rear section, drill new holes for the new motor mout, and then i have a Evo 5 "M"
Also the steering system has moved more backwards. This my be fine because of the more flex in the front section of the car, but i think to install an BL ESC it will be a horrable job......
Greetings Blueman
Old 06-20-2008, 10:24 AM   #1484
Send a message via MSN to jontang001
Greetings Blueman
http://www.tamiya.com/japan/download/rc_index.htm
Here comes the manual!!!
What a quick update....
Somewhere in Asia has started to sell the 5MS...
And my friend says you can't use previous setup on this car....totally different!!!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 06-21-2008, 04:23 AM   #1485
hobbipro's Avatar
Trader Rating: 21 (100%+)
I was going to order a MS from Rc Champ, they got them in yesturday, but by the time you add the price of the car, the bank fee, pay-pal fee, and EMS shipping your lookin at $480-$500 USD Wait till speedtech gets them, probably go for around $400.
So instead found a guy selling Evo 5's on ebay for $299 + S&h on fleabay, picked one of those up instead. Any building tips? It will get here next week. Most likely will go brushless, but I do have a 23T Tamiya motor I could throw in too.
hobbipro is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
