Tamiya TB Evolution V
#1396
Anti Dive in oneway stock racing
Hy there
I read in the TRF416 thread that Victor Wilck setuped his 416 at the DHI Cup with a 0,5mm shimm under the rear block of the front suspension. That perform a little anti dive.
This works great with a spool and stronger motors i think???
But does it also make sense in Stock racing with oneway? Has anybody tried it out?
I usual run on tarmac 1mm shims under the blocks, and on carpet (high grip, and tecnical) without the spacers. But i havent tryed anti dive or kickup yet.
Greetings from Austria
#1397
Hy there
I postetd this also in the TRF416 thread, and got the following back as answer:
last year, running on asfalt outdoor with medium grip and a 19T motor i experienced that using anit-dive or kickup wasn't my thing.
kickup was really bad as the car put all his weight on the front wheels when when slowing down for a corner with a one-way. this made the car really loose in the back. tried anti-dive too but this gave too little steering so i left them parallel to the deck.
when driving stock i dont think you brake that much. anti-dive, as said before here somewhere, makes your car more stable during braking as it transfers less weight to the front of the car. when driving stock you want an as high as possible corner speed because accelerating with a stock motor while having a nice straight-end speed dont go together...
Greetings Blueman
#1398
FOR SALE
I AM SELLING MY FI"V"E if anyone is interested......Good price too.
For sale Section or Click on MY Name and Find the Post EVO 5
#1399
Hello to you all
Does anybody have a good setup for this car it will be on a tarmac track quit short with one straight about 40 to 50 feet long and the rest is quit technical it is a high grip track it will be runing 19t stock
hope you can help
hope you can help
#1400
That is my setup for tarmac:
Dampers: 3 hole plate, 40 oil, with bushing (red one), blue springs front, yellow rear.
Castor: 4°, Chamber: 1,5° F+R, Toe in: 2° (rear A+E, front D+D)
ride height: 5mm and 5,5mm, droop: front 5mm, rear 4mm.
I also use the inner hole of the upper arm mounts at he bukheads, and 1mm shims under the blocks all around. the rest is all like in the kitsetup.
Greetings blueman
#1401
Thanks blueman
We'll set it up and see what the other half makes of it
#1403
I never run a lipo in my evo5 or in an other car, but i think the fit of a pak like this is no big (dremel) problem
I tok some pictures of my car today, where you can see that the place of the batery slots are not coverd by the top deck, if you ok straight from the top on the car.
Only in the end of the front and the rear the deck gets a little wider. The clearance between the lower and the upper deck is 25mm.
By the way, last trainingssession i tested a spool first time in my Evo5 with a LRP 17Turn machine. It was very very nice to drive. But for the 13.5 Turn BL
class i think the oneway will be faster.
If there are still any questions, dont be afraid to ask.
Greetings Blueman
#1404
brushless gearing?
OK, I have a TB EVO V and I have just bought a Mamba Sidewinder 5700. What gearing should I run? Can I convert to 48P gears? I'm not even sure what pitch the standard gears are......maybe 0.4? what does that mean anyway.....0.4mm pitch??? Anyway, a ball park figure for the pinion/spur ratio would help. I get the motor next week (hopefully).
#1405
Well, I am not sure what that is equivalent to... but a 1:6.5 cannot hurt and work your way up or down... the gear ratios accordingly.
The standard gears that come with the car are 0.4 Module, basically 64p.
#1406
I ride also 48dpi spurs and pinions in my car, at the moment a 71t Spur with a 26t pinion. 1 : 6,65 for a 17T Brushed motor.
For me i usual ride 48dpi in all of my cars, because these are very easy to get, and i have a huge range of pinions already in stock.
I made a little gearing chart where you can look wich spur and pinion matches with the ratio you prefer. (for 48dpi)
Greetings Blueman
Greetings Blueman
#1407
Reading through this thread, several have asked about the internal gear ratio. I cannot find anything in the manual, but have seen some online sources say 2.4370. Is it in the manual anywhere? If so, anyone know the page?
Thanks,
Thanks,
#1408
Hi there kmeyer
yes the internal gear ratio is as you have founf i have been using 2.4375 as this is what i was told by other on here It is in the manual on page 16 see pic below circled in red.
have fun.
have fun.
#1409
Excellent. I see it. Thank you!
I just replaced a spur gear in about 10 minutes. I think it will take about 5 next time. I used the process of poping the shaft out.
