Like Tree1Likes
Old 08-16-2007, 02:21 AM   #1306
Blueman Austria's Avatar
Originally Posted by dsrbltoys View Post
this is the correct part number for evo IV spool, it works fine in evo V. The pic attatched is for a 415, ignore that pic. You can use the white replacement outdrives for 415 with the long sleeve, it works well, without any shims...
white outdrive for 415 = 9804268
blue sleeve for 415 = 9804267
perfect fit in EVO V!!!
Have you no problem with the gear mesh ? In my car the Evo4 Spool is a little noisy, because the distance between the gear tooth is a little to small.
I sanded 3 tens mm from the alloy spool part where the Ring gear is mounted, and now it runs so smooth as with the onway.
Maybee my Gearcase is a littel bit narrower
Greetings from austria
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 08-16-2007, 10:28 AM   #1307
dsrbltoys's Avatar
Nope, I have NO shims, and it fits perfect!!!
dsrbltoys is offline   Reply With Quote
Old 08-21-2007, 01:51 PM   #1308
I have ask and read that the Evo 4 bevel gear set wrong fit the Evo 5. But can someone please let me know why? Is it larger? Thicker? Diff pitch...etc. I really want to get the evo 4 Al gear set, and want to know if it is even possible to modify it to fit.
chumanji is offline   Reply With Quote
Old 08-21-2007, 06:52 PM   #1309
pole_position's Avatar
Hi
Any reason why you need to put on those Evo IV gears into a Evo V?
I did the reverse which I have plugged in the Evo V bevel & diff gears with the alum. diff joints into an old Evo IV. Running well so far...
pole_position is offline   Reply With Quote
Old 08-22-2007, 06:59 AM   #1310
Default The future of the Evo Series
Hy there!
What do the Evo5 drivers think out there. Will there be a new Evo (5MS or 6) in the nearer future, or is the shaft layout at the max. development level?
How is the Evo Series running for Tamiya. Is it a car that makes sense to continue, or will Tamiya concentrate only on beltdrive systems?
For me the shafties are always my first choice. Becaues in Stock racing, (what i am usualy do 23T and 17T) The car works very well, but i also have to say that i never runned any 415 yet.
What do you out there think what the future will bring ?
Old 08-22-2007, 10:42 AM   #1311
Looking at the current trend, it will need a popular class (probably 19T) to drive shaft driven cars in major races.
Else, it may take a few years like we had seen eg. Yokomo MR4TC to MR4TC-SD to MR4TC-BD... for the trend to swing back the cycle again to shaft driven cars...
Whatever it is, it is all down to personal taste... as both has their pros and cons...
Old 08-22-2007, 07:34 PM   #1312
dsrbltoys's Avatar
Originally Posted by pole_position View Post
Hi
different tooth count wich equals different internal ratio. Also the small gear mounts differently. IV uses screw, V uses Eclip.
Old 08-23-2007, 01:19 PM   #1313
MrUnlimited's Avatar
Hi guys,
I was wondering if the centre spool of the Evo 5 will fit my Yokomo SD lcg. Inner diameter of the shaftbearing is 5mm.
Here is my message in the mr4tc-sd lcg thread: http://www.rctech.net/forum/showthre...65#post3609165
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 08-27-2007, 10:36 PM   #1314
Default Evo 5 Asphalt Setup Hint!
Hy there!
I dont know if anyone has tried it already, but it worked very well on my car last race meeting.
I have tried to upper the rollcenter 1mm, by using the shims under the suspension blocks all around.
After that the corner in was the same, but it felt a little bit smoother over all.
The laptime was not very faster, but the car felt more comforteble.
For carpet you should use no shims under the blocks.
If anyone of you have expirience, please reply.
Greetings Blueman
Old 08-28-2007, 10:12 PM   #1315
bxpitbull's Avatar
Any of you Evo V owners used to be Pro4 owners? If so, do you know if the upper and lower bulkheads fit or can be modified to fit the Pro4? Those aluminum bulkheads with diff covers are trick and would make the Pro4 bulletproof....like the Evo V. Anyone?
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 08-29-2007, 09:45 AM   #1316
Trader Rating: 30 (100%+)
I've owned the Pro4, EVO IV, & EVO V, but I didn't try to fit any of the EVO's bulkheads onto the Pro4. I don't think it would really fit correctly. I'm pretty sure the mounting holes are very different as the pattern itself isn't the same. Then, the next issue would be if the measurements of the drivetrain would fit. I think you should either buy an EVO V or try to fit the Pro4 suspension onto the EVO V. That may be easier to do.
wrxnfx is offline   Reply With Quote
Old 08-29-2007, 09:54 AM   #1317
bxpitbull's Avatar
I have extra Pro4 lower chassis plates and parts. I was pondering buying the bulkheads and sizing them on one of my chassis plates, building a car up that way to see how the holes line up and how the bearings fit. If they parts didnt fit, then I would just give sell them for cheap. GUyisdamgood, Rocketracer, anyone else?
Old 09-08-2007, 03:24 AM   #1318
Hi, good to be part of the evo 5 club, i'm building my first evo ever
Only one problem, i have never assembled a hi tech car, such as this, and
do not know how one determines when to use shims?
I am at the very first assembly stages, assembling the prop shaft to the lower bulkhead with the 2 bearings and the manual shows to shim it with four 0.1mm shims, should i go with what the manual says? How do i know when i have shimmed correctly? It all feels the same with or without shims to me? the bearing seem to fit in fine with or without sims, i hope i can get my head around this.
It does not make sense 100% , hope anyone can help, Is there a way to test and feel for any "play" at some stage to determine this?
ST
skytrooper is offline   Reply With Quote
Old 09-08-2007, 05:28 AM   #1319
Send a message via ICQ to rcnewb2004
Try as per manual first, or read http://www.tamiyausa.com/articles/fe...article-id=226
There's a pretty good article to read up on.
rcnewb2004 is offline   Reply With Quote
Old 09-08-2007, 08:58 AM   #1320
Thanks Rcnewb,i'll go with what the manual says and hope for the best.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
