Like Tree1Likes
Old 05-07-2007, 11:32 AM   #1216
peejay's Avatar
Originally Posted by tamiyarcracer
Try it out and let us all know.
You noticed too
peejay is offline   Reply With Quote
Old 05-12-2007, 11:58 PM   #1217
Justinian's Avatar
I'm wondering what a good setup on an asphalt track would be too. I'm using the out of box setup and it's pretty good at the beginning of the race evening, but as the track gets more grip in the evening , I end up rolling the car when going hard into corners. I use 36s...most guys use softer tires.... I've tried to go easy with the traction compound in the later heats, but it doesn't seem to help. I'm guessing I need to get stiffer springs, heavier shock oil, and perhaps move some of the shock mounting positions out a bit... and maybe go down to 32 tires to make up for some of the slipping from the stiffer setup??? I haven't gotten into tuning these type of cars yet, so I'm guessing..... Anybody have a couple of setups for a short asphalt track with medium to high grip???
I had the rolling problem with my old XXX-S as well, so It's probably something having to do with the car setups...(or the driver )
Other than the rolling issue, I like how the Evo V handles... it turns pretty well and is a bit tougher than the XXX-S when it hits a wall....
Justinian, Emperor and Roman God of Barrel-Rolls and Broken Parts...
________________________________________________
-Tamiya Evo V
-CRC T-Fource
-Losi XXX-S
-Darkside I-Force 10th scale pan car (under construction)
-Associated B4, T4
-Losi XXX-CR, XXX-4
"Evil will always triumph over good, because good is dumb!" :
-Dark Helmet, master of the Dark Side of the Shwartz......
Justinian is offline   Reply With Quote
Old 05-13-2007, 11:57 AM   #1218
TryHard's Avatar
When you say rolling, do you mean it phyiscally rolls onto it's roof?
If so, there's two things that can cause this.... too stiff a setup, or too soft a setup. It sounds from description that it's the too soft option causing problems, although what sort of track is it your running on? I'm assuming a high grip asphalt?
If your happy with the balance, and just want to cure the rolling issue, first thing to try is removing the roll bars. This will let you know for certain if it is car being too soft that is the problem. If thats the case, get hold of some stiff bars (you can buy a complete Evo5 set, with soft, med and hard) and use them. Also look into goin up a spring rate all round, Tamiya Blues or HPI silvers are a good choice.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-14-2007, 01:00 AM   #1219
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
anyone got a good setup for a low grip asphalt track?
thx
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 05-14-2007, 01:01 AM   #1220
double post
Castle Hill Raceway
Old 05-16-2007, 12:09 AM   #1221
Justinian's Avatar
HiH
Ed
Yeah, it will lean hard then "turtle" on it's roof. I suspect the suspension is too soft. I just put on Blue springs all around and went to stiffer anti roll bars... I'll see this Friday night if that cures the problem.... Thanks for the advise!
-Tamiya Evo V
-CRC T-Fource
-Losi XXX-S
-Associated B4, T4
-Losi XXX-CR, XXX-4
Old 05-16-2007, 12:52 AM   #1222
has anyone noticed any torque steer in their Evo 5? If so what motor were u running?
Castle Hill Raceway
Old 05-16-2007, 11:17 AM   #1223
Trader Rating: 30 (100%+)
I have a Mamba Max 7700 in mine and no torque steer.
wrxnfx is offline   Reply With Quote
Old 05-16-2007, 03:19 PM   #1224
how do the gears hold up?
Castle Hill Raceway
Old 05-17-2007, 10:21 AM   #1225
No problems so far. It could be that I don't punch it very hard off the line very often.
Old 05-17-2007, 10:23 AM   #1226
No problems so far. It could be that I don't punch the throttle very hard off the line very often.
Old 05-23-2007, 02:04 AM   #1227
quick question guys,
what is binding? and how can you tell when your gears are binding?
Cheers
Castle Hill Raceway
Old 05-24-2007, 01:04 AM   #1228
anyone?
Castle Hill Raceway
Old 05-24-2007, 04:05 AM   #1229
TryHard's Avatar
Binding is when the gear feel tight as you turn them. Best way to test it is remove everything from the end of the drive train you want to test, leaving just the diff and input shaft
Then slowly rotate the gears, and see if you can feel any tight spots in the gears. If there is, try adding or removing some shims, otherwise, replace the gears.
I did find that with the kit instructions, the shiming was close to spot on. There was a little bit of play in the input shafts, so I played around for a while to get that perfect.
On another point, my Evo has now been sold, someone on ebay got a bargin at 125!!!!!
HiH
Ed
Old 05-24-2007, 08:40 AM   #1230
Blueman Austria's Avatar
@Ed
Why have you sold your Evo5 ? Are you more satisfied with your MRE ?
By the way, have you ever run it on tarmac?
When yes, have you used the 1mm up rollcenter spacer under the toe blocks?
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
