Old 04-21-2007, 01:55 PM   #1186
OleC's Avatar
Originally Posted by TryHard
hmm, I think I might have an answer to this...
You mention you are using the TA05 steel outdrives. I've had a quick look at some pictures (unfortuantly I don't have any to hand atm, so don't know if this is fully correct), and it would appear that the flange to hold the bearing in place is thinner on steel cup, than on the standard Evo4 black plastic cup. This would mean the bearings could be placed closer together, enabling a drop in fit...
Do you still have the plastic outdrives? any chance you could confirm if this is the case?
Cheers
Ed
I never thought of that, but you might just be right I'll check ASAP and post back!
OleC is offline   Reply With Quote
Old 04-23-2007, 04:51 AM   #1187
hye Try Hard ,i got a question for you
i was checking your Toe Blocks excel located at
http://www.thard.co.uk/excel/ToeBlocks.xls
it is for TRF and evo 4, but i think is the same for evo5 right?
so, i thought that evo 5 came with 2 deg of rear toe in of the box with XA+E blocks but your excel shows that that combination is 3 deg toe in
so question is evo 5 cames wth 3 degre of rear toe out ? or maybe your excel is wrong? maybe the excel doesnt work for evo 5?
thanks in advance
DrKucho is offline   Reply With Quote
Old 04-23-2007, 11:50 AM   #1188
Okay, I tested the EVO 4 spool with EVO 5 Gear, TA05 steel outdrives as well as stock outdrives. The stock didn't feel too bad but it was a little tight. As I rotated the gear, I would hit a spot after three revolutions or so where the gears would stick. I didn't have that problem when using the steel outdrives. The drivetrain was still very smooth, but still a "little (tiny bit)" tighter than normal. I think it's raceable though.
So, Steel outdrive "yes"...stock outdrives "No"
DOTMAN is offline   Reply With Quote
Old 04-23-2007, 12:52 PM   #1189
TryHard's Avatar
thanks in advance
Yup, the chart is the same for the Evo5, as the blocks are the same as thoose for the 415 (Evo4's are the same width, but 1mm taller).
Stock settings is 3deg. there is 0.5deg between each block, and the blocks go narrowest to widest
1XD, 1XC, 1XB, 1XA, 1X, 1A, 1B, 1C, 1D, 1E
With 6 steps between XA and E, this equals 3 degrees (6 x 0.5=3 )
HiH
Ed
Old 04-23-2007, 12:52 PM   #1190
TryHard's Avatar
Interesting... sounds like this is whats needed to use the spool then
Cheers
Ed
Old 04-23-2007, 02:35 PM   #1191
THX a million Tryhard
Old 04-23-2007, 04:03 PM   #1192
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
hey Guys,
At the moment i am trying to get more steering out of my evo 5, i am pretty much running the stock setup on smooth concrete. any tips?
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 04-23-2007, 04:15 PM   #1193
Cheers
Ed
Yeah, I think a gear break in session would be very beneficial too
Old 04-23-2007, 04:40 PM   #1194
Originally Posted by surrealmaterial
hey Guys,
Cheers
more steering on a evo5? the car steers a lot already, if your car is not gettin into turns might be becuase wrong tires , lots of toe in , front springs very hard, front damping too thick ... i dont know , there is a lot of stuff to check ...
Old 04-24-2007, 10:26 PM   #1195
quick question guys, is anyone using these on their car?
http://www.rcmart.com/catalog/produc...ducts_id=23174
cause i bought some and the bearings are too small and dont fit properly......
is there anyway i can make them usable with my car?
Cheers
Castle Hill Raceway
Old 04-25-2007, 12:11 AM   #1196
peejay's Avatar
Cheers
RCMart is a bit short on detail, and unfortunately so is the Yeah Racing website with respect to bearing sizes. Assume you mean your TB05 (950) bearings are too small? Try using 1150s.
peejay is offline   Reply With Quote
Old 04-25-2007, 02:11 PM   #1197
where can i buy 4 of those?
Castle Hill Raceway
Old 04-26-2007, 02:56 PM   #1198
Default Aluminium Joint set
Hi everybody.
I write you from spain, so first of all, sorry for my bad english
I have seen some of you with aluminium joint set on you evo V diff and one-way.
What joint set will fit? TA-05? TRF? Do you have to do any modification?
thank you for your help.
oscarin2000f is offline   Reply With Quote
Old 04-26-2007, 03:29 PM   #1199
Originally Posted by oscarin2000f
Hi everybody.
evo V came with alu cup joints in both diff and one way already .....
por cierto yo tambien soy espaņol
Old 04-26-2007, 03:53 PM   #1200
Hola Drkucho.
The question is for an EVO IV, sorry.
I have posted it here because i canīt find the oficial post of evo IV.
Thank you.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
