Like Tree1Likes
Old 04-15-2007, 12:33 PM   #1156
TryHard's Avatar
Default First Dibs...
Hi All,
Well, I'm selling my Evo5, so gonna give you all first dibs
Car come with the following extras;
RC Champ Blue Alu/Titanium screw kit
Hexheaded ball studs (used on camber and steering links)
Tamiya Aluminium Front Diff (with ceramic diff balls),
Evo4 Spool,
Titanium Nitride coated inner hinge-pins and Shock shafts,
1mm down type lower shock retainers,
Titanium steering turnbuckles,
Low Friction shock parts,
2 extra chassis stiffeners,
0.5mm and 1mm suspension block spacers (4ea)
1X suspension block to allow 2.5 rear toe-in
Extra pair of Tamiya H0 aluminium rear hubs (0.5mm lower axles),
Selection of gear meshing shims,
Spare set of short LWT arms,
Spare 2 and 4 Hub carriers,
Set of 2 hole tamiya pistons,
Spare front bevel gear, and 2 spare pinion gears.
Protoform DNA1 bodyshell
Car has only been used indoors in carpet, and probably has only 20 race meetings under it. Chassis is in good condition, and has been well looked after. Car has a very free drivetrain (spent a lot of time getting that right )
I'm looking for $350 for the lot, which given the car is worth $370 new, plus all the extras (least $150+), I don't think is a bad deal... but I'm open to offers. Please contact me for postage.
I'll be putting the car onto ebay tomorrow, just thought I'd give everyone on here a chance first...
Regards
Ed
Tamiya TB Evolution V-dscf0089.jpg   Tamiya TB Evolution V-dscf0088.jpg   Tamiya TB Evolution V-dscf0086.jpg   Tamiya TB Evolution V-dscf0087.jpg   Tamiya TB Evolution V-dscf0090.jpg
Old 04-15-2007, 01:11 PM   #1157
Titanium steering knuckles ???
DrKucho is offline   Reply With Quote
Old 04-15-2007, 01:28 PM   #1158
TryHard's Avatar
Well spotted... opps... changed.
Old 04-15-2007, 04:13 PM   #1159
Send a message via ICQ to rcnewb2004
Dang... may i be nosy and ask why are you parting w/ ur car tryhard? You have done so much work on it...
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 04-16-2007, 04:21 AM   #1160
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
does anyone know were i can get the alliminium servo mounts for the evo 5?
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 04-16-2007, 05:33 AM   #1161
TryHard's Avatar
Well, numerous really.
I've been driving Tamiyas for a while now (since early 2004), and recently wanted a change, so brought the new Losi.
That means I have three top line tourers, and somethings gotta lose out as I can't really justify having three. So the Evo is having to go. Feel a little bit of regret with it tbh, never really nailed an ubber setup, was close, but my 415 always felt a bit easier to drive...
Anyway, thats pretty much the reasons.
Ed
Old 04-16-2007, 05:37 AM   #1162
TryHard's Avatar
Cheers
Get the ones for the evo4
http://www.speedtechrc.com/store/ebp...id=276&id=1797
They fit fine, and are what I use on my evo5, and MRE
Old 04-16-2007, 01:22 PM   #1163
thanks
Castle Hill Raceway
Old 04-16-2007, 01:31 PM   #1164
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Originally Posted by MDawson
has anyone found a manufacturer for spools yet?
Mark... I'm also looking for one. Ran the car first time at TA 3 weeks ago... one way felt great, but I bet it will be even better with a spool on.
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 04-16-2007, 02:01 PM   #1165
TryHard's Avatar
Now, this isn't a trick I've tried... but you could remove the balls from a front diff, and tighten up the outdrives hard. Worth a punt if your desperate for a spool.
HiH
Ed
Old 04-16-2007, 03:06 PM   #1166
I heard conflicting reports that the EVO IV spool would work. Im gonna test it tonight to see.
DOTMAN is offline   Reply With Quote
Old 04-17-2007, 01:10 AM   #1167
TryHard's Avatar
I tried to get an Evo4 spool to work, however I found it a silly tight fit, the bevel gear seemed to be spaced closer to the centre than on the 5's front axles. Sufice to say, I took it out and used a one-way...
Old 04-17-2007, 07:07 AM   #1168
infokiz's Avatar
The evo4 spool is a tight fit. You would need to machine some material off the long end to get a little extra play. I don't have any access to those kind of tools so I don't use it.
Ed with your idea with of using a diff. I learned this from the rock crawlers they do it with the TLT's because the center diff on those is TA04 ball diff. they replace the balls with Traxxas friction pegs they apparently fit perfect and lock the diff up fairly good. I haven't tried it yet as my TLT is in pieces,but it might be worth a try.
infokiz is offline   Reply With Quote
Old 04-17-2007, 09:23 AM   #1169
That's too bad. There are a number of guys here who'd like to run the car in the Reedy race but they don't allow one-ways
Old 04-17-2007, 10:46 AM   #1170
TryHard's Avatar
Just do the front diff trick then... they allow a diff dont they If you really want to get it tight, cut out some sandpaper to the same size of the diff rings, and replace the balls with then.
The Losi uses a similar trick, replacing the balls with a hard plastic pad.
HiH
Ed
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
